Sorry, don’t know, that is part of lwiP not FreeRTOS.
You are right, but FreeRTOs is also used with “libc” that provides “errno”, perhaps one possibility is to modify the “get_errno” and “set_errno” routines to write the error in a task variable using “configNUM_THREAD_LOCAL_STORAGE_POINTERS”.
When defining configNUM_THREAD_LOCAL_STORAGE_POINTERS, a number of objects can be stored in the task’s context.
This object has the size of a pointer, but it does not have to be a pointer. An integer may be casted and stored as a pointer.
The FreeRTOS+FAT library already uses 3 of these storage pointers, one of the to stored the last errno seen. Another pointer stores the CWD (current working directory).
Here are the two access functions:
/* The errno is stored in a thread local buffer. */
static portINLINE void stdioSET_ERRNO( int iErrno )
vTaskSetThreadLocalStoragePointer( NULL, ffconfigCWD_THREAD_LOCAL_INDEX, ( void * ) ( iErrno ) );
static portINLINE int stdioGET_ERRNO( void )
void *pvResult;
pvResult = pvTaskGetThreadLocalStoragePointer( ( TaskHandle_t )NULL, ffconfigCWD_THREAD_LOCAL_INDEX );
return ( int ) pvResult;
I know that in some environments errno has an instance per thread in some magic way, but I don’t think that it will work together with FreeRTOS.
debugasm wrote:
The Lwip have a routine to set “errno”, I just need to modify this function to use FreeRTOs.
If you are using newlib, you only have to set
configUSE_NEWLIB_REENTRANT to 1
in your FreeRTOSConfig.h
In newlib,“errno” and other global variables like “stdout” are defined as macros and will actually point to a task local reent structure. On single core systems, there’s just a pointer called “_impure_ptr” that is updated by FreeRTOS on task switch (see task.c).
I use Xilinx SDK that use “libc”. I don’t have found a way to compile “newlibc” and use it in this environment. So I was building a new library to be used with FreeRTOs usable even in debugging unlike other libraries.
Why does FreeRTOS team not develop an internal library like “Micrium μc / os-xxx”, which integrates the main libraries and then free themselves from external bookcases ?
