Alex
(Chun Luo)
April 4, 2023, 1:59am
1
Newbee here trying to use the Demo blinky project on Terasic De10 standard board,
I’m trying to use the Esplice to build the target but failed:
my toolchain is
arm-linux-gnueabihf-gcc
working on windows but if it is need to work on Linux I’ll try linux.
Another thing is that is there a Makefile project that can be an example?
I want to get rid of the Esplice and DS-5 ASAP.
Reguards.
rawalexe
(Anubhav Rawal)
April 11, 2023, 8:32pm
2
Thank you for your concern, We will look into it provide you with updates
aggarg
(Gaurav Aggarwal)
April 12, 2023, 5:10am
3
Did you use one of the per-configured projects or are you trying to create a project yourself? Most likely, the flags you pass to the compiler and assembler are not correct. Can you share the compiler command line you are using?
Alex
(Chun Luo)
April 12, 2023, 8:43am
4
It’s the demo project with new DS-5 without the CROSS COMPILE.
Instead I used the ARM 6 toolchain which has a lot of issues.
Here is my tool chain settings:
Accourding to Intel, their ARM DS tool didn’t support HPS RTOS system until release 23.2.
So I want to use ARM 6 tool chain instead of Altera baremetal tool chain.
If you guys share me with your original project settings for this cyclone V soc HPS demo would be very helpful.
Reguards
Alex
aggarg
(Gaurav Aggarwal)
April 12, 2023, 11:16am
5
Can you link the demo which you are referring to?
Alex
(Chun Luo)
April 13, 2023, 3:16am
6
Hi, Gaurav
My bad, but I can’t put the links for Im a new user
The support demo is called:
Altera Cyclone V SoC RTOS Demo
Reguards.
Alex
aggarg
(Gaurav Aggarwal)
April 13, 2023, 5:59am
7
rawalexe
(Anubhav Rawal)
April 15, 2023, 12:23am
9
Just dropping the suggestion from Richard Barry in here
karahulx
(RAHUL KAR)
May 17, 2023, 2:10pm
11
Hi @Alex
Just wanted to confirm if the suggestion posted by Richard, was useful in solving the issue?
