Trying to do WiFi provisioning for esp32 devices. The idea is to create an access point and start a webserver which gives capability to user to insert their WiFi credentials to device. We tried using esp-idf WiFi provisioning example and it worked. But when we try it through Aws FreeRTOS the provisioning is not working.
Can you please share which AWS FreeRTOS release you are using ?
Also are you trying to use the espressif app [Link] ?
