FreeRTOS V10.3.0 support for Cortex R-5
Does the latest version of freeRTOS support ARM Cortex R-5 port, if yes, I do not see a ARM R-5 folder in the following path : FreeRTOSv10.3.0\FreeRTOS\Source\portable\GCC…
Is there anyway I can import it?I am new to this, need clarification on this.
The two choices should be called “ARM_CR5” and “ARM_CRx_No_GIC”. You would pick the one that matches your specific processor. If you don’t see those folders, you may need to download the distribution again.
