I was planing to use FreeRTOS+UDP for a LPC43xx based project, but I’m thinking of using FreeRTOS+TCP instead. To decide this I would like You opinion.
My application will need only UDP (for the moment, but normally the appetite comes while eating so my client probably will ask for TCP in future!).
I do not have Flash size problems, but RAM usage could be important (If possible i’d like to use only the internal 136K SRAM of the LCP43xx, and a lot of this RAM may be needed for my Application (Data buffers)).
I will require a “commercial” license for the Stack, do You have any idea what the TCP stack will cost?
The question about the commercial license: please drop an email to FreeRTOS.org and you will be contacted about that.
FreeRTOS+UDP is mature and well-tested.
FreeRTOS+TCP is built upon +UDP. If you ever think of using more features like LLMNR, NBNS, FTP, or HTTP, you better start using +TCP now. The focus will be more and more on +TCP.
