system
(system)
1
emanuelcsm wrote on Wednesday, January 28, 2015:
I’m trying to use FreeRTOS here. I have the development board STM32-H407 from Olimex.
I wanna send/receive a strings using UDP, but the demo project for IAR does not have the functions for UDP.
Des anyone have an EW_ARM project example that uses UDP connection?
Thanks
rtel
(Richard Barry)
2
rtel wrote on Wednesday, January 28, 2015:
If you have a network driver, and don’t want to do anything too fancy with the driver, then porting is just a matter of implementing a few functions.
http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/FreeRTOS_UDP_Porting.shtml
Best to start with a known good FreeRTOS project, and a known good Ethernet driver (STM32Cube has a driver) then stick the two together.
