godi22 wrote on Saturday, February 23, 2019:
I work with a Atmel/Microchip SAM4E µC and use TWI (I²C).
Operating system is freeRTOS V10.0.1
Compiler: GNU Arm Embedded Toolchain 7-2018-q2
I replaced the twi_master (from ASF V3.44) init, read and write functions with the equivalent functions (without async) from the freertos_twi_master file.
Now I have the problem, that the queue.c calls in the function xQueueGenericSend (line 731) the configASSERT makro, because QueueHandle_t xQueue is a NULL-Pointer.
If I add into the xQueueGenericSend function a return when the xQueue is NULL, it seems to be all correct. Because, I receive the same data with the Atmel twi_master software.
Unfortunately, I can not quite understand where the NULL pointer comes from, or why this occurs at all. It must have something to do with the semaphores.
Has anyone already had the same problem and solved, or an idea why it comes to the NULL pointer?
