Hello @ActoryOu,
I’m not certain about your target platform, but here are the functions for the STM32F756NGHx generated with CubeMX:
void HAL_MspInit(void)
/* USER CODE BEGIN MspInit 0 */
/* USER CODE END MspInit 0 */
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_RCC_SYSCFG_CLK_ENABLE();
/* System interrupt init*/
/* PendSV_IRQn interrupt configuration */
HAL_NVIC_SetPriority(PendSV_IRQn, 15, 0);
/* USER CODE BEGIN MspInit 1 */
/* USER CODE END MspInit 1 */
* @brief ETH MSP Initialization
* This function configures the hardware resources used in this example
* @param heth: ETH handle pointer
* @retval None
void HAL_ETH_MspInit(ETH_HandleTypeDef* heth)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(heth->Instance==ETH)
/* USER CODE BEGIN ETH_MspInit 0 */
/* USER CODE END ETH_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_ETH_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**ETH GPIO Configuration
PG14 ------> ETH_TXD1
PG13 ------> ETH_TXD0
PG11 ------> ETH_TX_EN
PC1 ------> ETH_MDC
PA1 ------> ETH_REF_CLK
PC4 ------> ETH_RXD0
PA2 ------> ETH_MDIO
PC5 ------> ETH_RXD1
PA7 ------> ETH_CRS_DV
GPIO_InitStruct.Pin = GPIO_PIN_14|GPIO_PIN_13|GPIO_PIN_11;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN ETH_MspInit 1 */
/* USER CODE END ETH_MspInit 1 */
* @brief ETH MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_ETH_MspDeInit(ETH_HandleTypeDef* heth)
/* USER CODE BEGIN ETH_MspDeInit 0 */
/* USER CODE END ETH_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ETH_CLK_DISABLE();
PC1 ------> ETH_MDC
HAL_GPIO_DeInit(GPIOG, GPIO_PIN_14|GPIO_PIN_13|GPIO_PIN_11);
HAL_GPIO_DeInit(GPIOC, GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5);
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7);
/* USER CODE BEGIN ETH_MspDeInit 1 */
/* USER CODE END ETH_MspDeInit 1 */
I’ve made the changes to the order of the included header files as you suggested, but there seems to be no change. The device still doesn’t respond to ping requests.
Thanks again for your help!
