FreeRTOS+TCP will not reply ping after unplug/plug eth cable when sending data
Thanks :slight_smile:
This is the only change I made to solve the link status problem. Before that I had a PHY access problem , that I solved by rewriting xSTM32_PhyRead() and xSTM32_PhyWrite().
I’ll let more experienced people than me answer this question. :slight_smile:
I’ll just add that MV88E6071 is not a PHY like LAN8742A, it’s a switch with 5 ports, and it’s connected to the MCU via a MII interface.
