Please consider this post as more of a discussion than a bug-report, but I will start with what I believe is a bug.
Let’s consider an implementation where there is absolutely no CRC offloading.
In FreeRTOS_IP.c in prvAllowIPPacket() we have:
#if( ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM == 0 ) { /* Some drivers of NIC's with checksum-offloading will enable the above define, so that the checksum won't be checked again here */ if (eReturn == eProcessBuffer ) { /* Is the IP header checksum correct? */ if( ( pxIPHeader->ucProtocol != ( uint8_t ) ipPROTOCOL_ICMP ) && ( usGenerateChecksum( 0U, ( uint8_t * ) &( pxIPHeader->ucVersionHeaderLength ), ( size_t ) uxHeaderLength ) != ipCORRECT_CRC ) ) { /* Check sum in IP-header not correct. */ eReturn = eReleaseBuffer; } /* Is the upper-layer checksum (TCP/UDP/ICMP) correct? */ else if( usGenerateProtocolChecksum( ( uint8_t * )( pxNetworkBuffer->pucEthernetBuffer ), pxNetworkBuffer->xDataLength, pdFALSE ) != ipCORRECT_CRC ) { /* Protocol checksum not accepted. */ eReturn = eReleaseBuffer; } else { /* The checksum of the received packet is OK. */ } } } #else
An ICMP packet with a bad IP checksum will and does get received instead of dropped. I don’t understand why there was an extra check added to the if() that deals with checking the IP checksum. Removing the ICMP part fixes the issue:
#if( ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM == 0 ) { /* Some drivers of NIC's with checksum-offloading will enable the above define, so that the checksum won't be checked again here */ if (eReturn == eProcessBuffer ) { /* Is the IP header checksum correct? */ if( ( usGenerateChecksum( 0U, ( uint8_t * ) &( pxIPHeader->ucVersionHeaderLength ), ( size_t ) uxHeaderLength ) != ipCORRECT_CRC ) ) { /* Check sum in IP-header not correct. */ eReturn = eReleaseBuffer; } /* Is the upper-layer checksum (TCP/UDP/ICMP) correct? */ else if( usGenerateProtocolChecksum( ( uint8_t * )( pxNetworkBuffer->pucEthernetBuffer ), pxNetworkBuffer->xDataLength, pdFALSE ) != ipCORRECT_CRC ) { /* Protocol checksum not accepted. */ eReturn = eReleaseBuffer; } else { /* The checksum of the received packet is OK. */ } } } #else
That concludes the bug-report. Let me know what you think… I might be missing something.
While I was messing around with checksum offloading disabled I realized that when I enable it in my driver I still see weirdness and this is where I need other people’s opinion. It turns out that the offloading in the MCU that I’m using ( atsame70q21 ) only does IP/TCP/UDP. This leaves the door open for other ICMP, IGMP and probably other protocols to be assumed as filtered by the driver and not checked by the stack.
Please chime in with what other MACs calculate.
In my case, the atsame70 can filter frames with bad IP/TCP/UDP checksums but will not attempt to filter packets with a bad ICMP checksum. Since I had ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM enabled, the stack was just assuming everything is fine.
I haven’t checked, but I’m afraid most MACs will be limited to IP/TCP/UDP which would mean that there were some wrong assumptions made when designing FreeRTOS+TCP. If I’m correct, the code would have to be modified to perform CRC calculation and verification for protocols like ICMP, IGMP, etc. even when the network driver provides rx crc offloading. The same logic also may apply to tx offloading when outgoing pings are enabled, but I haven’t checked that part of the code.
What do you guys and gals think, should we have a little more fine grained control of what the stack takes for granted?
