Hi Team,
We are using FreeRTOS+TCP 4.0.0 with multiple VLANs and endpoints:
- VLAN10 → IP 100.64.10.5
- VLAN14 → IP 100.64.14.5
- DLT socket bound to 100.64.14.5:3490
During debugging we observed that when a TCP SYN arrives from VLAN10, FreeRTOS+TCP still creates the child/peer socket and proceeds through LISTEN → SYN_RECEIVED → ESTABLISHED, even though the socket is bound to VLAN14 IP.
In prvHandleListen_IPV4 Current code:
if( ( pxEndPoint != NULL ) &&
( pxTCPPacket->xIPHeader.ulDestinationIPAddress == pxEndPoint->ipv4_settings.ulIPAddress ) )
We changed it to:
( pxTCPPacket->xIPHeader.ulDestinationIPAddress == pxSocket->xLocalAddress.ulIP_IPv4 ) )
With this change:
- VLAN10 connection attempts are rejected
- Child/peer socket is not created for VLAN10
- Only VLAN14 is able to establish the TCP connection
Could you please confirm whether comparing against “pxSocket->xLocalAddress.ulIP_IPv4” is the correct approach for multi-VLAN systems?
Also, could this have any side effects for multi-endpoint or multi-homed systems?
