Is the freeRTOS+TCP experimental multi-interface up to date with the current, non-experimental version in regards to security vulnerability fixes. I keep seeing FreeRTOS+TCP security vulnerability articles when researching on google. Just want to put my mind at ease.
I want to use this TCP stack on a micro controller that has two MACs, this should do the trick, right?
My other option is lwip, which I’m unfamiliar with and which I have read lacks multi-interface support. I’ve used freeRTOS and like its documentation and ease of use. This will be my first venture into FreeRTOS+TCP
Thanks Richard and Hein. Looking back the LWIP issues with multi-interface are coming from dated forum posts.
Anyway I’ve been trying to port the the TCP+ multi over and experiencing issues with the FreeRTOS_DHCP_IPv6.c file.
I’m getting an error that DHCPMessage_IPv4_t is not defined (It’s not defined in the file). Anyway there is a DHCPMessage_IPv6_t struct defined within the file. I can just add the IPv4 struct, but I’m uncertain if this was the program writer’s original intent, or if this is just a bug and the programmer meant to write IPv6.
The source file FreeRTOS_DHCP_IPv6.c has existed, but it was decided not to support DHCPv6 for now. You can remove it from your build.
In stead there will be a IPv6 protocol called Router Advertisement (RA).
Here you will find a later releases of FreeRTOS+TCP /multi /IPv6.
You can look at it, use it, but please don’t expect that it is ready for a public release. People are working hard to get all the security tests done and make it ready.
