FreeRTOS TCP keep-alive under heavy load
Hello, I have a Zynq board with one of the processor running FreeRTOS+TCP. It communicates over both UDP (for sending raw data) and TCP. The keep-alive feature is also enabled.
I noticed that under heavy loads of UDP data (~400 Mbps), sometimes (I believe) the keep-alive packet gets lost or rather the sequence number of the keep-alive packet is off from the previous TCP packet’s sequence number. For example, see packet #118, 157, 210 of the wireshark capture: https://1drv.ms/u/s!ApMttKXHCCb9gR8kbCYtNZ1COzag?e=gBGsyA (sorry, it doesn’t seem like I am able to upload files to FreeRTOS atm).
This isn’t a big deal to me, but I’m wondering if this is a bug? Or if this has happened to anyone else before? The board is running on FreeRTOS v9.0.0
I see the FreeRTOS version number in your post - can you please also let us know the TCP stack version number - it should be at the top of each source file. From the FreeRTOS version number I suspect you are using an old stack version.
There was a bug in earlier versions of the Xilinx/Zynq driver, that is repaired in PR #1798
This PR has not been merged yet.
You can see the driver here
The bugs had to do with updating peripheral registers: it was necessary to read-back the register after writing to it, which works like a memory barrier.
In case you are using xil_printf, have a look at this change in FreeRTOSIPConfig.h:
#define configPAUSE_AFTER_XIL_PRINTF_MSEC	20
#define configPRINT_STRING( X ) \
	xil_printf( X ); \
	vTaskDelay( pdMS_TO_TICKS( configPAUSE_AFTER_XIL_PRINTF_MSEC ) )
Without the delay, lots of logging messages get lost. The delay takes place in the logging task, so there is no performance loss.
Sorry, I forgot to tell that you can find more information about the PR in its predecessor PR #1628
Especially these:
  • In emacps_send_handler() : read-back the XEMACPS_TXSR registers in ISR context after clearing it
  • In emacps_send_message() : read-back the XEMACPS_NWCTRL register after setting it
I hope that this will solve the problem with keep-alive packets.
TCP version is FreeRTOS+TCP Labs Build 160919
I tried applying the patch on PR1798/1628. Specifically, I added the calls to read back the registers in:
  • emacps_send_handler(): ( void ) XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_TXSR_OFFSET);
  • emacps_send_message(): ( void ) XEmacPs_ReadReg( ulBaseAddress, XEMACPS_NWCTRL_OFFSET );
However, I still see the problem persist. Perhaps I will try updating to the latest FreeRTOS… there seems to be quite a few patches to the TCP library for Xilinx.
For the time-being, I can disable keep-alive as the application regularly sends it’s own keep-alive packet as well.
Please use the entire new driver with all source files from the Zynq directory.
What I observed is that sending packets sometimes failed when there was a continuous stream of incoming packets. The new version doesn’t have this problem. I tested this with IPERF3, running it in both directions.
It is always good to use the latest kernel version, but it won’t help for the failing transmissions.
I always recommend using a high-level way of sending are-you-alive packets. When they are responded, it means that the counter application is also still alive, not only the TCP/IP driver.
Hein
Hi Hein,
I upgraded to the latest version of FreeRTOS/FreeRTOS+TCP and applied PR1798 and ran the system over night. I did not observe any problems related to keep-alive packets.
I was wondering what’s the timeline like for having PR1798 merged into main?
Thanks
