The number of UDP messages that you can receive without reading them, is indeed
limited by ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS.
For TCP a circular “stream buffer” is created for each direction. TCP data must be
buffered, and kept in a buffer until the transmission has been acknowledged by the
peer.
This TCP housekeeping of data is complicated. I tried to make clear how it works in 2
pictures ( attached to this post ).
The implementation of UDP sockets is a lot simpler. It has a list ( List_t ) of Network Buffers that were received. Note that FreeRTOS_recvfrom() has a zero-copy possibility, so that you can peek directly into a Network Buffer.
There is an important setting for UDP sockets, limiting the maximum number of received packets:
#ifndef ipconfigUDP_MAX_RX_PACKETS
/* Make positive to define the maximum number of packets
* which will be buffered for each UDP socket. Can be
* overridden with the socket option FREERTOS_SO_UDP_MAX_RX_PACKETS
#define ipconfigUDP_MAX_RX_PACKETS 0u
Suppose that you get a UDP attack: thousands of packets are fired to your UDP
port, the attack will not disturb the device because at most ipconfigUDP_MAX_RX_PACKETS
network buffers will be stored.
Thanks for the answer. I have an additional question. How are these 2 parameters related, ipconfigUDP_MAX_RX_PACKETS and ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS?
When I increase ipconfigUDP_MAX_RX_PACKETS from (3) to (10), I get an Assertion fail:
“Assertion failed in file …/src/FreeRTOS-Plus-TCP-multi/FreeRTOS_IP.c, line 1610”.
Line 1610 of FreeRTOS_IP.c is this part of the code:
static void prvProcessEthernetPacket( NetworkBufferDescriptor_t * const pxNetworkBuffer )
EthernetHeader_t *pxEthernetHeader;
volatile eFrameProcessingResult_t eReturned; /* Volatile to prevent complier warnings when ipCONSIDER_FRAME_FOR_PROCESSING just sets it to eProcessBuffer. */
configASSERT( pxNetworkBuffer );
Ken, thanks a lot for your big effort to find the cause of this problem.
The driver x_emacpsif_dma.c worked fine as long as it handled a single NIC. You found that when it serves two EMAC’s, corruption may occur. So the problem was only present in the /multi version.
My stupid: two tasks were storing temporary data in common variables.
These simple changes were made to avoid mentioned problem:
