Either I have something misconfigured, or there is some mishandling of a 64 byte minimum ack packet.
Wireshark flags tcp acks and fin, acks as having a Frame check sequence error. I think this is due to sending 0’s for the last 4 bytes. I think that a FCS packet is minimum 64, and a non FCS is 60 perhaps? I can’t find anything so far in the configuration that targets this issue.
Several EMAC’s ( like, apparently ATWILC1000 ), are able to padd bytes as well.
In that case, you can keep ipconfigETHERNET_MINIMUM_PACKET_BYTES undefined.
