Hi all,
While debugging, why I sporadically get very long RTT (>250ms) while the normal RTT is around 5ms, I stumbled upon the following messages on the console:
FreeRTOS_TCP/Source/FreeRTOS_IP.c:2740: CRC error: 1234 location 0
FreeRTOS_TCP/Source/FreeRTOS_IP.c:2740: CRC error: 4321 location 0
Looking at the Source, I don’t see how the CRC error 4321 can be set, but location remains 0? E.g. the only line of code that can set the crc error to 4321 (ipUNHANDLED_PROTOCOL) is where xLocation gets set to 7… so, I’d expect xLocation to be 7 and not 0…
I’m running FreeRTOS Kernel V10.4.0 with FreeRTOS+TCP V2.3.2 on a NIOS2 Softcore with a simple driver (not zero copy). The ethernet mac has a built-in (and activated) function, which should discard frames with a incorrect FCS, so, I’m wondering why CRC errors exist (in the IP stack) at all…
