FreeRTOS+TCP based project can't build after editing the ioc file in STM32CubeIDE
I used the STM32_Nucleo_H723ZG_FreeRTOS_TCP project as starting point to make a TCP server on the base of the NUCLEO-H743ZI2 board. I was able to compile it and run in STM32Cube IDE 1.18.1. After that I decided to try to change MCU STM32H723ZGT6 to STM32H743ZIT6 in the project files. I changed MCU in all project’s configuration files by hand, replaced *.ld and *.s files etc - so the project was working nicely after all this manual corrections.
But as the last step I decided to try to open in IDE the ioc file. It asked me to migrate to a new version of CubeMX- after that I see the MCU drawing and I can change settings. After that I close ioc file and some files in the project automatically are regenerating - I see it as the contents of e.g. main.c changing. But after that I can’t build my project anymore.
The beginning of errors looks next:
C:/Users/irek/STM32CubeIDE/workspace_1.18.0/CmdBoard/Libraries/FreeRTOS-Plus-TCP/source/portable/NetworkInterface/STM32Hxx/NetworkInterface.c:64:6: error: #error stm32hxx_hal_eth.h is possibly not included
64 | #error stm32hxx_hal_eth.h is possibly not included
C:/Users/irek/STM32CubeIDE/workspace_1.18.0/CmdBoard/Libraries/FreeRTOS-Plus-TCP/source/portable/NetworkInterface/STM32Hxx/NetworkInterface.c:111:8: error: unknown type name ‘ETH_HandleTypeDef’
111 | static ETH_HandleTypeDef xEthHandle;
The first error follows me into the file workspace_1.18.0\CmdBoard\Libraries\FreeRTOS-Plus-TCP\source\portable\NetworkInterface\STM32Hxx\NetworkInterface.c
which is very deep inside FreeRTOS+TCP. The code is next
#ifndef STM32Hxx_HAL_ETH_H
  • The ST HAL library provides stm32h7xx_hal_eth.{c,h}.
  • This FreeRTOS+TCP driver renamed these files to stm32hxx_hal_eth.{c,h}
  • by removing the ‘7’.
  • Please make sure that “portable/NetworkInterface/STM32Hxx” is included
  • in the include paths earlier than “STM32H7xx_HAL_Driver/Inc”.
  • and also make sure that you have defined ‘HAL_ETH_MODULE_ENABLED’
  • in your copy of “stm32h7xx_hal_conf”.
The STM32Hxx_HAL_ETH_H defined in the stm32hxx_hal_eth.h which is in the same folder.
So I really do not understand why ioc file kills the link with the FreeRTOS+TCP.
Just raw idea. In ioc file I left Ethernet connection disabled (as it was in the original project). Could it be that ioc disables Network adapter in the FreeRTOS+TCP? But how? And how to correct it?
Thank you in advance!
So I found that after ioc file closing the #define HAL_ETH_MODULE_ENABLED was commented in stm32h7xx_hal_conf.h file.
I enabled this line and after that I checked all points of the next part of NetworkInterface.c file:
And as a last step I found that the file \workspace_1.18.0\CmdBoard\Drivers\STM32H7xx_HAL_Driver\Inc\stm32h7xx_hal_eth_ex.h file disappeared from my project. Magic…
So after correcting all these problems now I can build my project.
But will all these problems appear again if I use ioc file - I’ll test it tomorrow.
Did you update the version of FreeRTOS+TCP as well or just the MCU and CubeMX version?
This could be because the ETH module was disabled in the IOC file in the original project, and the ETH init code was manually added instead of the IOC-generated one.
I believe this has to do with the migration of the CubeMX to the newer version.
They likly can as Cube re-writes the project file - I’d suggest confirming with ST. In any case, you should use git or a diff tool to examine the changes made by CubeMX and then pick the ones you need and discard the remaining.
