Is there a way to configure FreeRTOS + TCP in STM32CubeMX environment?
Don’t think so. Maybe a feature request to ST😉
I also don’t think that FreeRTOS+TCP is already included in the CUBE libraries.
But you can always add the library to your CUBE project.
You can also have a look here, where you find two STM32Fx demos. I run them using ST System Workbench. Each of the projects has a Makefile and a config.mk.
Thanks a lot. Will try.
