To whom it may concern,
I am interested in learning if FreeRTOS has a port to the Freescale i.MX6 Solo X SABRE-SD platform for either of the cores (A9 and M4). I do not see this listed on your supported platforms listing but am hoping you have support (CPU core + BSP) for this platform. We are in the beginning stages of a new product development and are interesting in using your RTOS. Please respond at your earliest convenience.
Although there is no official demo in the FreeRTOS download, we have been running FreeRTOS on the M4 core of the i.MX Solo part (on a Sabre board). FreeRTOS will actually run on any Cortex-M core without any porting being required. This is because the kernel is not dependent on any hardware outside of the Cortex-M core itself (the clock and interrupt controller are built into the core).
Do you have a bare metal application running on the hardware already? If so you should be able to add in the FreeRTOS source files, and install the FreeRTOS PendSV, SysTick and SVCCall interrupt, and be running. http://www.freertos.org/Creating-a-new-FreeRTOS-project.html
Items to watch out for are the configPRIO_BITS and configMAX_SYSCALL_INTERRUPT_PRIORITY settings. I’ve just checked our i.MX Solo project and find the following - which may or may not be correct ;o)
[more info below the code snippet]
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4 /* 15 priority levels */
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
If the Cortex-A9 core is using a standard ARM GIC (Generic Interrupt Controller) then FreeRTOS will also run on that without modification, provided you set the base addresses for the GIC correctly. Sometimes FreeRTOS will use their own IP for things like the interrupt controller, and MPU, etc. If that is the case on this part then some porting work will be required. I’m afraid I’ve never looked at the A9 core on this specific chip.
As I recall, and my memory might be wrong, we used GCC to build the code, ARM DS-5 to download and debug the code, and a D-Stream as the debugging interface. The M4 core must be clocked and enabled by the A9 core, but this can be done by peeking and poking the necessary registers using a debugger script - allowing you to develop on the M core without the A core running at all. It won’t boot like that though, to boot you need something actually running on the A core to problematically start the M core then load the excitable binary image.
