masrurmahmood wrote on Wednesday, August 09, 2017:
I’m running into an issue where the code is stuck in prvStartFirstTask(). What could be the reason for FreeRTOS to get stuck here? What can I do to debug this issue?
Please advise.
Please advise.
rtel wrote on Wednesday, August 09, 2017:
The first task is started using an SVC interrupt. Have you installed
the FreeRTOS interrupt handler? See “Special note to ARM Cortex-M
users:” in the “The application I created compiles, but does not run”
FAQ on the following page: http://www.freertos.org/FAQHelp.html
