I have some probles with memory reads operations in multiple core platforms. I have a dual-core with a Cortex-A9 with U-Boot and a Cortex-M4with FreeRTOS. From the FreeRTOS I read data pointing to the physical address of the memory:
If the memory is written by one core and read by another you will
probably need to perform a cache flush after the write before it becomes
visible to the reader.
As a hardware question this really falls outside of FreeRTOS support. I
would recommend describing the issue to the hardware manufacturer and
see what they recommend.
Although this subject is a bit off-topic for FreeRTOS, I’ll give my two cents:
● Are you sure that there is no memory-address translation within uboot? If you write to address 0x91F000, is that really the first byte of the shared memory?
● Are you sure that the mapping for that physical memory within the Cortex-M4 is the same? Also at address 0x91F000?
● is memory access from within the Cortex-M4 without caching? If not a refresh would be necessary
● and last of all: wouldn’t it be possible to reserve a block of uncached shared memory for this purpose?
