Hello everyone, I am currently trying to use FreeRTOS. I want the energySaving task to call uploadData and MQTT first. However, I keep encountering an “assert failed: xQueueSemaphoreTake queue.c:1653 (( pxQueue ))” error when using Semaphore. I tried commenting out uploadData and MQTT, and it runs successfully if they are commented out. I would like to know what could be causing this issue.
void TaskUploadData(void *pvParam) {
while (1) {
HTTPClient http;
if (xSemaphoreTake(semStart, portMAX_DELAY) == pdTRUE){
Serial.println("HTTP");
String tmpurl = (url + apiKey) + "&field1=" + String(tempB, 1) + "&field2=" + String(rh) + "&field3=" + String(int(soilH)) + "&field4=" + String(pm1) + "&field5=" + String(pm25) + "&field6=" + String(pm10) + "&field7=" + String(pressure);
http.begin(tmpurl);
http.GET();
http.end();
xSemaphoreGive(semUpload);
//上傳資料至Thingspeak,可依照Field不同調整tmpurl中的順序,時間可在最後vTaskDelay調整
//最上方預留2秒給其他感應器讀取數據,同時確保有讀取到資料才上傳,若溫度與濕度為0則不上傳(尚未讀取到資料)
//!因Thingspeak限制資料傳輸間隔最少需要15秒,因此下方至少需13000(加上方2000)才可達到15秒間隔!
void TaskMQTT(void *pvParam) {
MQTTClient.setServer(MQTTServer, MQTTPort);
while (1) {
Serial.println("MQTT");
if (!MQTTClient.connected()) {
Serial.println("MQTT connecting");
vTaskSuspend(lowBatt);
while (!MQTTClient.connected()) {
MQTTClient.connect(clientID);
vTaskDelay(100 / portTICK_PERIOD_MS);
Serial.println("MQTT Connected!");
vTaskResume(lowBatt);
if (MQTTClient.connected()) {
MQTTClient.publish("HomeSenser/esp32/temp", String(tempB).c_str());
MQTTClient.publish("HomeSenser/esp32/rh", String(rh).c_str());
MQTTClient.publish("HomeSenser/esp32/soilH", String(soilH).c_str());
MQTTClient.publish("HomeSenser/esp32/pm1", String(pm1).c_str());
MQTTClient.publish("HomeSenser/esp32/pm25", String(pm25).c_str());
MQTTClient.publish("HomeSenser/esp32/pm10", String(pm10).c_str());
MQTTClient.publish("HomeSenser/esp32/pressure", String(pressure).c_str());
MQTTClient.publish("HomeSenser/esp32/SolarTemp", String(tempSolar).c_str());
MQTTClient.publish("HomeSenser/esp32/battV", String(battV).c_str());
MQTTClient.publish("HomeSenser/esp32/battA", String(battA).c_str());
MQTTClient.publish("HomeSenser/esp32/battW", String(battW).c_str());
xSemaphoreGive(semMqtt);
void energySaving(void *pvParam) {
esp_wifi_set_ps(WIFI_PS_NONE);
while (1) {
vTaskDelay(1000 / portTICK_PERIOD_MS);
xSemaphoreGive(semStart);
xSemaphoreTake(semMqtt, portMAX_DELAY);
xSemaphoreTake(semUpload, portMAX_DELAY);
esp_sleep_enable_timer_wakeup(13500000); //13.5秒
Serial.println("進入 Light Sleep 模式");
Serial.flush();
esp_light_sleep_start();
//WiFi計時器,若超過三分鐘未連線則重啟動
void wifiRestart(TimerHandle_t xTimer) {
esp_restart();
void setup() {
Serial.begin(115200);
xTaskCreate(TaskReadPMS, "Read PMS Sensor", 1500, NULL, 1, NULL); //使用904
xTaskCreate(TaskReadSoilrh, "Read Soil Sensor", 1200, NULL, 2, NULL); //使用852
xTaskCreate(TaskReadBMP, "Read BMP180", 1800, NULL, 2, NULL); //使用1244
xTaskCreate(TaskReadTemp, "Read Solar Temp ", 2000, NULL, 2, NULL);
xTaskCreate(TaskReadINA, "Read INA226 ", 3000, NULL, 2, NULL);
xTaskCreate(TaskWiFi, "WiFi connect", 3000, NULL, 1, NULL); //使用1856
xTaskCreatePinnedToCore(TaskUploadData, "Upload Data", 5500, NULL, 2, &uploadData, 0); //使用3204
xTaskCreatePinnedToCore(TaskMQTT, "MQTT Service", 4000, NULL, 2, &mqtt, 0); //使用1452
xTaskCreatePinnedToCore(energySaving, "Energy Saving", 4000, NULL, 1, &lowBatt, 0); //使用1856
timer = xTimerCreate("WiFi connection timer", (180000 / portTICK_PERIOD_MS), pdFALSE, (void *)1, wifiRestart);
semStart = xSemaphoreCreateBinary(); // 用來控制 B 和 C 是否可以開始
semMqtt = xSemaphoreCreateBinary(); // 控制 B 任務
semStart = xSemaphoreCreateBinary(); // 控制 C 任務
delay(1000);
