Hi Support Team,
Project Name: freeRTOS integration with the WiFi module’s code using the STM32H743ZI
I am trying to integrate the freeRTOS library with one of the WiFi modules by using the host MCU STM32H743ZI. I am using the STM32cube IDE.
I generated the freeRTOS middleware and integrated the code successfully. I have created the 2 tasks like Application task and the Driver task. I gave a higher priority to the Driver task as compared to the Wireless task.
This is the configuration that I am using:
#define RSI_APPLICATION_TASK_PRIORITY 1 // Wlan task priority
#define RSI_DRIVER_TASK_PRIORITY 2 // Wireless driver task priority
#define RSI_APPLICATION_TASK_STACK_SIZE (512 * 2) // Wlan task stack size
#define RSI_DRIVER_TASK_STACK_SIZE (512 * 2) // Wireless driver task stack size
I am able to create the first task (RSI_APPLICATION_TASK_PRIORITY) and after that, I called the OS Task scheduler. later I am trying to create the second task (RSI_DRIVER_TASK_PRIORITY), and there my control goes into an infinite loop. After suspending the debug mode I saw my control always goes into the below (if condition) part which is available in the port.c file:
if( ulCurrentInterrupt >= portFIRST_USER_INTERRUPT_NUMBER )
For reference, I have attached here the port.c file and freeRTOS .ioc file images.
Please help me to resolve this issue.
Thanks in advance.
Regards,
Kaniaya Sharma
