The convention in the current atmel header file is:
__inline unsigned int AT91F_AIC_ConfigureIt (
AT91PS_AIC pAic, // \arg pointer to the AIC registers
unsigned int irq_id, // \arg interrupt number to initialize
unsigned int priority, // \arg priority to give to the interrupt
unsigned int src_type, // \arg activation and sense of activation
void (*newHandler) () ) // \arg address of the interrupt handler
Where the AIC peripheral is passed in as well.
Is there any chance that you can update the library version in the distribution so that it uses the library functions that are compatible with the current atmel standard.
What happens is that everytime I drop in a new FreeRTOS release into my source tree I end up wondering why it crashes and then I remember that I have to go in and modify the port.c file so that it passes the correct parameters to the configure call.
Is this using GCC? I seem to recall in GCC the macro was altered and placed in the application code (rather than using the one in the header) as the headers are written for IAR and are not to easy to include in GCC builds due to their inline statements.
The headers certainly compile fine now without alteration under gcc, not sure about older versions.
I’ve just downloaded the latest freertos and dropped in the latest atmel header that I have here and modified port.c and it compiles fine.
Well, actually under gcc 4.1.0 I get some warnings:
ompiling C (ARM-only): FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c
arm-elf-gcc -c -mcpu=arm7tdmi -mthumb-interwork -I. -gdwarf-2 -DROM_RUN -DSAM7_GCC -DTHUMB_INTERWORK -DVECTORS_IN_RAM -I. -Ihardware/include -IFreeRTOS/Source/include -I/Common/include -IFreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S -O0 -Wall -fomit-frame-pointer -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.lst -MD -MP -MF .dep/portISR.o.d -Wnested-externs -std=gnu99 FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c -o FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.o
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c: In function ‘vPortISRStartFirstTask’:
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:87: warning: nested extern declaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:87: warning: nested extern declaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:87: warning: redundant redeclaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:69: warning: previous definition of ‘ulCriticalNesting’ was here
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c: In function ‘SWI_Handler’:
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:107: warning: nested extern declaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:107: warning: redundant redeclaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:87: warning: previous declaration of ‘pxCurrentTCB’ was here
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:107: warning: nested extern declaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:107: warning: redundant redeclaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:113: warning: nested extern declaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:113: warning: redundant redeclaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:107: warning: previous declaration of ‘pxCurrentTCB’ was here
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:113: warning: nested extern declaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:113: warning: redundant redeclaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c: In function ‘vPreemptiveTick’:
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:151: warning: nested extern declaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:151: warning: redundant redeclaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:113: warning: previous declaration of ‘pxCurrentTCB’ was here
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:151: warning: nested extern declaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:151: warning: redundant redeclaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:162: warning: nested extern declaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:162: warning: redundant redeclaration of ‘pxCurrentTCB’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:151: warning: previous declaration of ‘pxCurrentTCB’ was here
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:162: warning: nested extern declaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:162: warning: redundant redeclaration of ‘ulCriticalNesting’
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c: At top level:
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:174: warning: redundant redeclaration of ‘vPortDisableInterruptsFromThumb’
FreeRTOS/Source/include/…/…/Source/portable/GCC/ARM7_AT91SAM7S/portmacro.h:218: warning: previous declaration of ‘vPortDisableInterruptsFromThumb’ was here
FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c:175: warning: redundant redeclaration of ‘vPortEnableInterruptsFromThumb’
FreeRTOS/Source/include/…/…/Source/portable/GCC/ARM7_AT91SAM7S/portmacro.h:219: warning: previous declaration of ‘vPortEnableInterruptsFromThumb’ was here
But these are due to a change in the freertos code that nests some external declarations that wern’t like that in previous versions.
Humn…turning that off still didn’t fix those warnings:
Compiling C (ARM-only): FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c
arm-elf-gcc -c -mcpu=arm7tdmi -mthumb-interwork -I. -gdwarf-2 -DROM_RUN -DSAM7_GCC -DTHUMB_INTERWORK -DVECTORS_IN_RAM -I. -Ihardware/include -IFreeRTOS/Source/include -I/Common/include -IFreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S -O0 -Wall -fomit-frame-pointer -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.lst -MD -MP -MF .dep/portISR.o.d -std=gnu99 FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.c -o FreeRTOS/Source/portable/GCC/ARM7_AT91SAM7S/portISR.o
