Using FreeRTOS v7.1.0. Demo RX600_RX62N-RSK_Renesas.
This usually works OK except under heavy incoming traffic to my MAC/IP I occassionaly receive a packet of all zeroes from ulEMACRead() in response to a uipETHERNET_RX_EVENT. Using Microsoft Network Monitor this packet doesn’t appear on the wire.
How are you defining ‘heavy’ traffic in this case? It is perfectly possible to overwhelm a small microcontroller with very heavy traffic it can’t physically keep up with, but it should fail gracefully, in that, it should just miss packets and not do anything daft.
Thanks for your reply. I have written a VNC server app that runs on the RX62N. If the connected VNC client sends a large number of client pointer event messages due to rapid mouse movement, then I will receive the packet of all zeroes. It happens somewhat randomly.
Unfortunately one of the received RBF messages to set the client pixel format uses a zero as the message identifier and then my connection structure gets hosed.
I’m suprised that this gets through the FreeTCPIP stack since I wouldn’t think that the CRC was correct - but it comes into my application from the newdata() notification as a valid received packet.
If you cannot see the packet on the wire, then maybe it isn’t getting through the stack (because it doesn’t exist) but you are seeing a symptom of something else going wrong - maybe in the MAC driver/DMA interface.
I was going to suggest capturing a recording of the packets using Wireshartk, and then playing them back into the RX device so you could step through and see what happens, but if the packet isn’t on the wire, then it can’t be recorded.
Richard-
So in looking at this closer, it may be that either EMAC or FreeTCPIP is confused. Looking at the packet that is being presented to my application as newdata() and ack() the packet contents looks like part of the 16-bit frame buffer image that I had previously sent to the client - the screen has black (00 00), red (f8 00) and white (ff ff) pixels. The message header is not present in the payload, but it is only sent in the first packet of the frame buffer update response. This packet should never come back to the server, it is outgoing to the client only.
The first MAC address is the VNC server (my device), the second MAC address is the VNC client (my PC), the source IP address is my PC (192.168.1.110) the destination IP is my device (192.168.1.200), the port numbers are correct. Here’s the packet:
This packet doesn’t appear on the wire, but my application receives this via FreeTCPIP as newdata() and ack() - which I guess that it would be looking at the header, but the contents are not a message that I would expect to receive from the VNC client (Tight VNC Viewer).
Any ideas why this would be happening ? Have you seen anything like this before ?
Richard- OK - I think I see what is going on. In my rfb application, I’m checking for ack() then newdata(). In ack(), if I’m in the middle of sending the frame buffer then I prepare the next packet for sending, updating appdata and uip_len. When I exit ack() then newdata() is next and it looks like I’ve received what I’ve just sent. I’m going to try reversing the order of these calls, checking for newdata() first, then ack() to see if that will correct the problem. Any newdata() received while connected after initial handshaking doesn’t generate any responses - other than the return ACK.
Another interesting anamoly has appeared however. When I brought this hardware home to work on this weekend, and hooked it up to my LAN, the EMAC code is now stopping in the following function:
static void prvResetEverything( void )
/* Temporary code just to see if this gets called. This function has not
been implemented. */
portDISABLE_INTERRUPTS();
for( ;; );
This doesn't happen on the work LAN - can you please provide some insight as to why this is coded this way and why this would be happening on one LAN and not the other ?
Thank you !
I’ve never seen that function called, but as I remember it is called in response to error bits being set in the MAC registers (just from memory). If you go to where the function is being called, and set a break point on it, you should be able to see the cause.
Richard- Turns out that it is not a MAC error - just an indication that a fragmented packet has been received. In your function prvCheckRxFifoStatus() if FP0 is not set it indicates that a starting or continuous packet has been received:
static unsigned long prvCheckRxFifoStatus( void )
unsigned long ulReturn = 0;
if( ( pxCurrentRxDesc->status & ACT ) != 0 )
/* Current descriptor is still active. */
else if( ( pxCurrentRxDesc->status & FE ) != 0 )
/* Frame error. Clear the error. */
pxCurrentRxDesc->status &= ~( FP1 | FP0 | FE );
pxCurrentRxDesc->status &= ~( RMAF | RRF | RTLF | RTSF | PRE | CERF );
pxCurrentRxDesc->status |= ACT;
pxCurrentRxDesc = pxCurrentRxDesc->next;
if( EDMAC.EDRRR.LONG == 0x00000000UL )
/* Restart Ethernet if it has stopped. */
EDMAC.EDRRR.LONG = 0x00000001UL;
/* The descriptor contains a frame. Because of the size of the buffers
the frame should always be complete. */
if( ( pxCurrentRxDesc->status & FP0 ) == FP0 )
ulReturn = pxCurrentRxDesc->size;
/* Do not expect to get here. */
prvResetEverything();
return ulReturn;
Looking at the Renesas ethernet driver function _eth_fifoRead() this code copies the partial frame data when FP0 is not set:
* Function Name: _eth_fifoRead
* Description : Receives data and updates E-DMAC descriptor
* Arguments : p - pointer to descriptor
* : buf - pointer to data to receive
* Return Value : Number of bytes received for this descriptor
* : -1 Descriptor busy
* : -2 Frame error
int32_t ( ethfifo *p, int8_t buf[])
int32_t i, temp_size; /* byte counter */
ethfifo *current = p;
if( (current->status & ACT) != 0)
* Current descriptor is active and ready to receive or receiving.
* This is not an error.
return (-1);
* Current descriptor is not active.
* Process the descriptor and data received.
else if( (current->status & FE) != 0)
* Frame error.
* Must move to new descriptor as E-DMAC now points to next one.
return (-2);
/* We have a new data w/o errors to process. */
if ((current->status & FP0) == FP0)
/* This is the last descriptor. Complete frame is received. */
temp_size = current->size;
while (temp_size > BUFSIZE)
temp_size -= BUFSIZE;
* This is either a start or continuos descriptor.
* Complete frame is NOT received.
temp_size = BUFSIZE;
/* Copy received data from receive buffer to user buffer */
for (i = 0; i < temp_size; i++)
buf[i] = current->buf_p[i];
/* Return data size received */
return (temp_size);
Unfortunately the Renesas ethernet driver code is structured differently than EMAC.c and it’s not clear to me how I could assemble these fragments before returning from ulEMACRead().
