kingsob wrote on Wednesday, June 18, 2008:
I am trying to get my WiMi coordinator to run using FreeRTOS, so I am adding all files from my coordinator project into my freertos project (the dsPIC demo)…
everything is going great, until i get to the last file ConfigFuses.c. When I add this file, the project starts to run very slowly… it works… but the lights blink ALOT slower… if i remove this file, it continues to operate slowly… so i assume it is modifying a project setting that it should not be… but i got no idea which one it is
I have tried starting with an empty project, and simply include this file… so im faily confident it is this file causing the problems… and help would be greatly appreciated!
Derek
* FileName: ConfigFuses.c
* Dependencies:
* Processor: PIC18, PIC24F, PIC24H, dsPIC30, dsPIC33
* tested with 18F4620, dsPIC33FJ256GP710
* Hardware: PICDEM Z, Explorer 16
* Complier: Microchip C18 v3.04 or higher
* Microchip C30 v2.03 or higher
* Company: Microchip Technology, Inc.
* Copyright and Disclaimer Notice for MiWi Software:
* Copyright © 2006-2007 Microchip Technology Inc. All rights reserved.
* Microchip licenses to you the right to use, modify, copy and
* distribute Software only when embedded on a Microchip
* microcontroller or digital signal controller and used with a
* Microchip radio frequency transceiver, which are integrated into
* your product or third party product (pursuant to the sublicense
* terms in the accompanying license agreement).
* You should refer to the license agreement accompanying this
* Software for additional information regarding your rights
* and obligations.
* SOFTWARE AND DOCUMENTATION ARE PROVIDED “AS IS” WITHOUT WARRANTY OF
* ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION,
* ANY WARRANTY OF MERCHANTABILITY, TITLE, NON-INFRINGEMENT AND
* FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL MICROCHIP OR
* ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT, NEGLIGENCE,
* STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER LEGAL
* EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
* INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT,
* PUNITIVE OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST
* OF PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY
* CLAIMS BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE
* THEREOF), OR OTHER SIMILAR COSTS.
* File Description:
* Change History:
* Rev Date Description
* 0.1 11/09/2006 Initial revision
* 1.0 01/09/2007 Initial release
/************************ HEADERS **********************************/
#include "Compiler.h"
/************************ DEFINITIONS ******************************/
#if !defined(HI_TECH_C) && defined(__18F4620)
#pragma romdata CONFIG1H = 0x300001
const rom unsigned char config1H = 0b00000110; // HSPLL oscillator
#pragma romdata CONFIG2L = 0x300002
const rom unsigned char config2L = 0b00011111; // Brown-out Reset Enabled in hardware @ 2.0V, PWRTEN disabled
#pragma romdata CONFIG2H = 0x300003
const rom unsigned char config2H = 0b00001010; // HW WD disabled, 1:32 prescaler
#pragma romdata CONFIG3H = 0x300005
const rom unsigned char config3H = 0b10000000; // PORTB digital on RESET
#pragma romdata CONFIG4L = 0x300006
const rom unsigned char config4L = 0b10000001; // DEBUG disabled,
// XINST disabled
// LVP disabled
// STVREN enabled
#elif defined(HI_TECH_C) && !defined(__PICC__) && defined(__18F4620)
__CONFIG(1,HSPLL);
__CONFIG(2,PWRTDIS & BORDIS & WDTDIS);
__CONFIG(3,CCP2RB3);
__CONFIG(4,STVRDIS & XINSTDIS & LVPDIS);
__CONFIG(5,UNPROTECT);
#elif defined(__PICC__) && defined(_16F877A)
__CONFIG(0x3F3A);
#elif defined(__PIC24F__)
// Explorer 16 board
_CONFIG2(FNOSC_PRI & POSCMOD_XT) // Primary XT OSC with 4x PLL
_CONFIG1(JTAGEN_OFF & FWDTEN_OFF) // JTAG off, watchdog timer off
#elif defined(__dsPIC33F__) || defined(__PIC24H__)
_FOSCSEL(FNOSC_PRI); //primary osc
_FOSC(OSCIOFNC_OFF & POSCMD_XT) // XT Osc
_FWDT(FWDTEN_OFF) // Disable Watchdog timer
// JTAG should be disabled as well
#elif defined(__dsPIC30F__)
// dsPICDEM 1.1 board
_FOSC(XT_PLL16) // XT Osc + 16X PLL
_FWDT(WDT_OFF) // Disable Watchdog timer
_FBORPOR(MCLR_EN & PBOR_OFF & PWRT_OFF)
#elif defined(__PIC32MX__)
#pragma config FPLLMUL = MUL_16, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = XT, FNOSC = PRIPLL, FPBDIV = DIV_4, WDTPS = PS128
#if !defined(__18F4620) && defined(__18CXX)
#error "Please update the configuration words for your device."
