hoanganhtdh1 wrote on Thursday, October 31, 2013:
Dear My Bro !
I already used FreeRTOS for some embedded projects for some year time and It worked really perfectly until now. Currently i’m facing a difficult problem related to using High Speed Interrupt in FreeRTOS porting to PIC24H, hope you all can help me to though this problem. Thanks in advance
I created a small demo project for easy testing:
Two task:
// Task 1
if (xTaskCreate(RTOSTask_1, (signed char*) “[T1]”, configMINIMAL_STACK_SIZE*2, NULL, tskIDLE_PRIORITY + 1, &hTask1) == errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY)
LREP("\r\nCannot create Task 1.");
Display_Error(1000);
// Task 2
if (xTaskCreate(RTOSTask_2, (signed char*) “[T2]”, configMINIMAL_STACK_SIZE*2, NULL, tskIDLE_PRIORITY + 2, &hTask2) == errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY)
LREP("\r\nCannot create Task 2.");
Implement of tasks:
void RTOSTask_1(void* pvParameter)
while(1)
if (xSemaphoreTake(hTask1Semaphore, portMAX_DELAY) == pdTRUE)
putchar1(‘1’);
void RTOSTask_2(void* pvParameter)
while(1)
if (xSemaphoreTake(hTask2Semaphore, portMAX_DELAY) == pdTRUE)
putchar1(‘2’);
To let above two tasks running i use one Timer & one UART to give them Semaphores:
void attribute((interrupt, auto_psv)) _T2Interrupt (void)
_T2IF = 0;
static signed portBASE_TYPE xTaskWoken = pdFALSE;
xSemaphoreGiveFromISR(hTask1Semaphore, &xTaskWoken );
if( xTaskWoken != pdFALSE )
taskYIELD();
void attribute((interrupt, auto_psv)) _U1TXInterrupt()
_U1TXIF = 0;
putchar1('E');
void attribute((interrupt, auto_psv)) _U1RXInterrupt()
_U1RXIF = 0;
if(U1STAbits.URXDA == 1)
uint8 u8Recv = U1RXREG;
static signed portBASE_TYPE xTaskWoken;
xSemaphoreGiveFromISR(hTask2Semaphore, &xTaskWoken);
taskYIELD();
My Timer interrupts in every 100us, UART working at 230400 bps baudrate speed.
After running some second or minutes the program is crashed and the program jump to Traps:
_AddressError or
_StackError
I don’t know how this problem could happen. After a long investigating & testing i thought that the problem happen when the program running in & running out of the Interrupt service routine (ISR). It seems we need a couple of SAVE_CONTEXT() & RESTORE_CONTEXT() functions. but on PIC24 port there is no one like that.
Please you kindly give me some advises for this problem
Thank you all !
