On 8/14/2019 I downloaded FreeRTOS+POSIX and from reading the code in FREERTOS_POSIX_pthead_cond.c I believed I had found a race condition in pthread_cond_timedwait().
I could confirm the bug you reported on count underflow was a solid bug, and I do apologize for the delayed response to the forum post.
The bug had been fixed with the project re-uploaded to freertos.org lab. We did drop the communication on this change, which was also on us.
The most recent FreeRTOS+POSIX lab project could be downloaded here. https://www.freertos.org/FreeRTOS-Labs/RTOS_labs_download.html
POSIX is located under ./FreeRTOS-Plus/Demo/FreeRTOS_Plus_POSIX_with_actor_Windows_Simulator/lib/FreeRTOS-Plus-POSIX.
Please note that:
The folder strutcture has been changed.
This version (zip name 190820-*) of POSIX depends on atomic.h. (we made some performance improvements.)
Also, to your specific concern about pthread_cond_timedwait():
This function does test- test-and-set logic on counter decrement. This addresses the underflow issue you’ve reported. Please check prvTestAndDecrement().
pthread_cond_timedwait() mutex release and count semaphore take in 190820-* is not “atomic” in our implementation. Please kindly note this is different from POSIX specification. http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_cond_timedwait.html.
quote "These functions atomically release mutex and cause the calling thread to block on the condition variable cond; atomically here means “atomically with respect to access by another thread to the mutex and then the condition variable”
We are working on a better versioning scheme of freertos lab code. And hopefully next time the source control could state for itself for which version a user is consuming.
