dumarjo wrote on Wednesday, January 13, 2016:
HI,
We have worked with openOCD team to get the RTOS option of openOCD working with FreeRTOS for cortex-M MCU. We need to apply some modifications to get this work when FPU and/OR MPU is used.
The standard cortex-M3 or M4 is working properly with openOCD.
The problem is that openOCD cannot known if the port of freeRTOS is using MPU or FPU option. Without this knowledge, openOCD return a standard stack frame starting from the saved stack pointer on the taskTCB. This give false information in the FPU port since freeRTOS push on the stack the FPU register before saving the stack pointer in the TaskTCB.
What we did, we recreated the standard stack frame and save the stack pointer in the taskTCB and after that we push LR and if the FPU bit is set/clear/ we push the S16 to S31 register. This way on the FPU port we have the “standard stack frame” and openOCD continue to work with the FPU port. With this modification we can have gdb display task with all there calling stack.
Here the modification that we have made to the cortex-M4F port
portSTACK_TYPE *pxPortInitialiseStack( portSTACK_TYPE *pxTopOfStack, pdTASK_CODE pxCode, void *pvParameters )
/* Simulate the stack frame as it would be created by a context switch
interrupt. */
/* Offset added to account for the way the MCU uses the stack on entry/exit
of interrupts, and to ensure alignment. */
pxTopOfStack--;
*pxTopOfStack = portINITIAL_XPSR; /* xPSR */
pxTopOfStack--;
*pxTopOfStack = ( portSTACK_TYPE ) pxCode; /* PC */
pxTopOfStack--;
*pxTopOfStack = 0xDEEDBEEF; /* LR */
/* Save code space by skipping register initialisation. */
pxTopOfStack -= 5; /* R12, R3, R2 and R1. */
*pxTopOfStack = ( portSTACK_TYPE ) pvParameters; /* R0 */
pxTopOfStack -= 8; /* R11, R10, R9, R8, R7, R6, R5 and R4. */
/* A save method is being used that requires each task to maintain its
own exec return value. */
pxTopOfStack--;
*pxTopOfStack = portINITIAL_EXEC_RETURN;
pxTopOfStack++;
return pxTopOfStack;
void vPortSVCHandler( void )
__asm volatile (
" ldr r3, pxCurrentTCBConst2 \n" /* Restore the context. */
" ldr r1, [r3] \n" /* Use pxCurrentTCBConst to get the pxCurrentTCB address. */
" ldr r0, [r1] \n" /* The first item in pxCurrentTCB is the task top of stack. */
" ldr r14 , [r0, #-4] \n"
" ldmia r0!, {r4-r11} \n" /* Pop the registers that are not automatically saved on exception entry and the critical nesting count. */
" msr psp, r0 \n" /* Restore the task stack pointer. */
" mov r0, #0 \n"
" msr basepri, r0 \n"
" bx r14 \n"
" \n"
" .align 2 \n"
"pxCurrentTCBConst2: .word pxCurrentTCB \n"
void xPortPendSVHandler( void )
/* This is a naked function. */
__asm volatile
" mrs r0, psp \n"
" \n"
" ldr r3, pxCurrentTCBConst \n" /* Get the location of the current TCB. */
" ldr r2, [r3] \n"
" \n"
" stmdb r0!, {r4-r11} \n" /* Save the core registers. */
" \n"
" str r0, [r2] \n" /* Save the new top of stack into the first member of the TCB. */
" stmdb r0!, {lr} \n"
" \n"
" tst lr, #0x10 \n" /* Is the task using the FPU context? If so, push high vfp registers. */
" it eq \n"
" vstmdbeq r0!, {s16-s31} \n"
" stmdb sp!, {r3, lr} \n"
" mov r0, %0 \n"
" bl vTaskSwitchContext \n"
" mov r0, #0 \n"
" ldmia sp!, {r3, lr} \n"
" \n"
" ldr r1, [r3] \n" /* The first item in pxCurrentTCB is the task top of stack. */
" ldr r0, [r1] \n"
" \n"
" ldr r14 , [r0, #-4]! \n"
" tst r14, #0x10 \n" /* Is the task using the FPU context? If so, pop the high vfp registers too. */
" it eq \n"
" vldmdbeq r0!, {s16-s31} \n"
" ldr r0, [r1] \n"
" \n"
" ldmia r0!, {r4-r11} \n" /* Pop the core registers. */
" \n"
" msr psp, r0 \n"
" bx r14 \n"
" \n"
" .align 2 \n"
"pxCurrentTCBConst: .word pxCurrentTCB \n"
::"i"(configMAX_SYSCALL_INTERRUPT_PRIORITY)
For the MPU section, we use the MPU with the FPU at the same time, so we take the FPU port and merge it with the MPU port. We did the same modification to the FPU port + we need to move the MPU settings after the pcTaskName in the tskTaskControlBlock. A modification is also needed in the port.c file to store the control register after the pushing the standard register.
Here a sample of the modification for the MPU
StackType_t *pxPortInitialiseStack( StackType_t *pxTopOfStack, TaskFunction_t pxCode, void *pvParameters, BaseType_t xRunPrivileged )
interrupt. */
pxTopOfStack--; /* Offset added to account for the way the MCU uses the stack on entry/exit of interrupts. */
pxTopOfStack--;
*pxTopOfStack = ( StackType_t ) pxCode; /* PC */
pxTopOfStack--;
*pxTopOfStack = ( StackType_t ) pvParameters; /* R0 */
pxTopOfStack -= 8; /* R11, R10, R9, R8, R7, R6, R5, R4 */
pxTopOfStack--; // privileged data
if( xRunPrivileged == pdTRUE )
*pxTopOfStack = portINITIAL_CONTROL_IF_PRIVILEGED;
*pxTopOfStack = portINITIAL_CONTROL_IF_UNPRIVILEGED;
pxTopOfStack--;
pxTopOfStack++;
pxTopOfStack++;
static void prvRestoreContextOfFirstTask( void )
__asm volatile
" ldr r0, =0xE000ED08 \n" /* Use the NVIC offset register to locate the stack. */
" ldr r0, [r0] \n"
" ldr r0, [r0] \n"
" msr msp, r0 \n" /* Set the msp back to the start of the stack. */
" ldr r3 , [r0, #-4] \n" /* restore the privilege mode */
" msr control, r3 \n" /* set the privilege mode depending of what was initialised */
" ldr r14 , [r0, #-8] \n" /* restore the link register mode for FPU operation */
/* MPU configuration */
" ldr r3, pxCurrentTCBConst2 \n" /* Get the pxCurrentTCP pointer. */
" add r1, r1, #68 \n" /* Move onto the second item in the TCB... */
" ldr r2, =0xe000ed9c \n" /* Region Base Address register. */
" ldmia r1!, {r4-r7} \n" /* Read 2 sets of MPU registers. */
" stmia r2!, {r4-r7} \n" /* Write 2 sets of MPU registers. */
/* END of MPU configuration */
" isb \n"
" mov r0, #0 \n"
" bx r14 \n"
" \n"
" .align 2 \n"
__asm volatile
" mrs r0, psp \n"
" isb \n"
" \n"
" ldr r2, [r3] \n"
" \n"
" mrs r1, control \n" /* get the currect execution mode (privilege or user) */
" stmdb r0!, {r1} \n" /* push the privilege mode to the stack frame*/
" stmdb r0!, {lr} \n" /* save the current status of the FPU */
" it eq \n"
" \n"
" stmdb sp!, {r3} \n"
" mov r0, %0 \n"
" dsb \n"
" isb \n"
" mov r0, #0 \n"
" ldmia sp!, {r3} \n"
" ldr r3, pxCurrentTCBConst \n" /* Get the pxCurrentTCP pointer. */
" ldr r0, [r1] \n"
" \n"
" ldr r3 , [r0, #-4]! \n"
" it eq \n"
" ldr r0, [r1] \n" /* restore current stack pointer */
" \n"
" \n"
" msr psp, r0 \n"
" isb \n"
" \n"
#ifdef WORKAROUND_PMU_CM001 /* XMC4000 specific errata workaround. */
#if WORKAROUND_PMU_CM001 == 1
" push { r14 } \n"
" pop { pc } \n"
" \n"
" bx r14 \n"
" \n"
" .align 2 \n"
With this modification we can use the multithread display in Eclipse (via GDB). Those modifications are not very intruisive.
I’m sorry for the long post here but I want to have a good reference to this for other people know that this is possible to use with freeRTOS.
Regards
Jonathan
