beyersk wrote on Tuesday, June 26, 2007:
Hi
Does anyone know if there is a port for FreeRTOS that will run on the Atmel AT91SAM7A3 processor?
Thank you
Beyers Konig
Hi
Thank you
Beyers Konig
embeddedc wrote on Tuesday, June 26, 2007:
There are various SAM7 ports for various tools. I think they are nearly all the same, just different memory layouts. What is the difference with the SAM7A3 to say a SAM7S64? If it is just the memory then you should be able to use an existing port with just a different linker script.
