FreeRTOS-Plus-TCP unit test
I followed following instructions to run FreeRTOS-Plus-TCP unit test but I am seeing following error and I am not sure how to fix this. Any help will be appreciated.
Creating mock for queue…
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_task.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_list.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_queue.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_event_groups.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_IP.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_IPv6.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_Sockets.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_IP_Private.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_ARP.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_ND.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_UDP_IP.c.o
[ 2%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_DHCP.c.o
[ 3%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_FreeRTOS_DNS.c.o
[ 3%] Building C object CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/mocks/mock_NetworkBufferManagement.c.o
[ 3%] Linking C shared library lib/libFreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dylib
Undefined symbols for architecture arm64:
“_GlobalExpectCount”, referenced from:
_mock_task_Destroy in mock_task.c.o
_xTaskCreate_CMockExpectAnyArgsAndReturn in mock_task.c.o
_xTaskCreate_CMockExpectAndReturn in mock_task.c.o
_xTaskCreate_CMockExpectWithArrayAndReturn in mock_task.c.o
_xTaskCreateAffinitySet_CMockExpectAnyArgsAndReturn in mock_task.c.o
_xTaskCreateAffinitySet_CMockExpectAndReturn in mock_task.c.o
_xTaskCreateAffinitySet_CMockExpectWithArrayAndReturn in mock_task.c.o
“_GlobalVerifyOrder”, referenced from:
_xTaskCreate in mock_task.c.o
_xTaskCreateAffinitySet in mock_task.c.o
_xTaskCreateStatic in mock_task.c.o
_xTaskCreateStaticAffinitySet in mock_task.c.o
_xTaskCreateRestricted in mock_task.c.o
_xTaskCreateRestrictedAffinitySet in mock_task.c.o
ld: symbol(s) not found for architecture arm64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [lib/libFreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dylib] Error 1
make[2]: *** [CMakeFiles/FreeRTOS_Routing_ConfigCompatibleWithSingle_mock.dir/all] Error 2
make[1]: *** [CMakeFiles/coverage.dir/rule] Error 2
make: *** [coverage] Error 2
lcov: WARNING: (deprecated) RC option ‘lcov_branch_coverage’ is deprecated. Consider using ‘branch_coverage’. instead. (Backward-compatible support will be removed in the future.)
(use “lcov --ignore-errors deprecated,deprecated …” to suppress this warning)
lcov: ERROR: cannot read file test/unit-test/build/coverage.info!
Which OS and version are you using?
Those instructions are tested for Ubuntu 20.04
If you are using Ubuntu latest, you might need to take a look at this CI script that runs unit tests on Github: FreeRTOS-Plus-TCP/.github/workflows/ci.yml at main · FreeRTOS/FreeRTOS-Plus-TCP · GitHub
We have created a Github PR that updates the script and instructions to run on the latest Ubuntu here: Update scripts to run unit tests with respect to Ubuntu 24.04 by tony-josi-aws · Pull Request #1237 · FreeRTOS/FreeRTOS-Plus-TCP · GitHub
