I followed the tutorial [FreeRTOS-Plus-TCP and FreeRTOS-Plus-FAT Examples] on this site, and encountered an issue. While I can successfully ping the server using the IP address assigned by DHCP, I cannot ping it using the hostname defined by the mainHOST_NAME macro. (shown in the image below)
I observed that the mainHOST_NAME macro is referenced only once in the code attached, and it doesn’t meet the #if condition by default. I tried manually enabling this condition and setting ipconfigDHCP_REGISTER_HOSTNAME to 1, but the issue persists.
What could be the possible reasons for this, and how can I resolve it?
#if ( ipconfigUSE_LLMNR != 0 ) || ( ipconfigUSE_NBNS != 0 ) || ( ipconfigDHCP_REGISTER_HOSTNAME == 1 )
const char * pcApplicationHostnameHook( void )
/* Assign the name "FreeRTOS" to this network node. This function will
* be called during the DHCP: the machine will be registered with an IP
* address plus this name. */
return mainHOST_NAME;
