I’ve downloaded the latest windows simulator for OTA and configured the network interface, certificates, private key and broker end point. Then I build and ran the executable. When I run it the logging (listed below) mentions the network interface was successfully opened, but the application hangs.
In the debugger I can see the app hangs inside the function prvSimulatedPeripheralTimer( LPVOID lpParameter ) on the line:
Sleep( portTICK_PERIOD_MS );
Anyone here who knows what is causing this?
---------- logging--------------------------
0 0 [None] [DEBUG] [OTADemo] [prvMiscInitialisation:241] Seed for randomizer: 1642889854
1 0 [None] [DEBUG] [OTADemo] [prvMiscInitialisation:243] Random numbers: 0000640E 0000182C 000019EB 00003405
The following network interfaces are available:
Interface 1 - rpcap://\Device\NPF_{F1D50CAE-408D-45D6-91DA-906BCAC898D0}
(Network adapter ‘Intel(R) Ethernet Connection I217-LM’ on local host)
Interface 2 - rpcap://\Device\NPF_{68FF978D-7605-4DF3-AEBF-CE38E9CEB943}
(Network adapter ‘Microsoft’ on local host)
Interface 3 - rpcap://\Device\NPF_{71C5C9D7-BD5A-45AE-A8A7-D71AD9445FCA}
Interface 4 - rpcap://\Device\NPF_{DAAFE730-8636-46E9-826B-BC96645710B3}
Interface 5 - rpcap://\Device\NPF_{831B8D04-8477-4502-9D02-2E707C7D01CB}
The interface that will be opened is set by “configNETWORK_INTERFACE_TO_USE”, which
should be defined in FreeRTOSConfig.h
Attempting to open interface number 1.
Successfully opened interface number 1.
