FreeRTOS on RX63N
Hi!
I am working on a project using e2studio, RX63N microcontroller, GCC compiler and FreeRTOS. I downloaded the FreeRTOS archive, but there is no RX63N demo project in it.
I added FreeRTOS to my RX63N e2studio project manually, but it does not work. I can not be sure that I added FreeRTOS correctly. For example, I can’t find the info about changing the interrupt vectors. Can someone please provide a working project for RX63N, e2studio and GCC?
When I create a FreeRTOS object, this happens. Firstly, “pvPortMalloc” is called, near the end of it “xTaskResumeAll” is called, then “taskENTER_CRITICAL”, then “portDISABLE_INTERRUPTS()”. An then an “INT_Excep_SuperVisorInst” exception occurs.
Thank you!
This version has a 63N project that uses the old IDE, but can still be used as a reference: https://github.com/FreeRTOS/FreeRTOS/tree/V10.4.1/FreeRTOS/Demo/RX600_RX62N-RSK_GNURX
There is also a 64M example for e2studio that may be better: https://github.com/FreeRTOS/FreeRTOS/tree/V10.4.1/FreeRTOS/Demo/RX600_RX64M_RSK_GCC_e2studio
Hi.
Thank you. That’s exactly what I did. I added FreeRTOS manually to my RX63N project by analogy with RX64M project.
But I get this Supervisor Exception.
The solution was to switch to supervisor mode.
