jshentu wrote on Saturday, May 21, 2016:
I am experiencing failure with malloc() function. Details of the target system is given as below:
MCU: LPC1788FBD208
OS: FreeRTOS
SDRAM: MT48LC4M16A2
Original Evaluation Kit: UEZGUI-1788-70WVT
Sample Project: uEZ_v2.06_SourceForge
I am using the heap_3.c module. Function malloc() is dead at first time when it is called, requiring
76 bytes to be allocated. When I check the configuration of the heap size, it is far bigger than
the required size. Could you technical support guys help identify the problem? Thanks in advance.
heap_3 code
void *pvPortMalloc( size_t xWantedSize )
void *pvReturn;
vTaskSuspendAll();
pvReturn = malloc(xWantedSize );
xTaskResumeAll();
#if( configUSE_MALLOC_FAILED_HOOK == 1 )
if( pvReturn == NULL )
extern void vApplicationMallocFailedHook( void );
vApplicationMallocFailedHook();
return pvReturn;
Heap Size defined in FreeRTOSConfig.h
#ifndef configMINIMAL_STACK_SIZE
#define configMINIMAL_STACK_SIZE ( 128 )
#ifndef configTOTAL_HEAP_SIZE
#define configTOTAL_HEAP_SIZE ( ( size_t ) (( 32 * 1024 ) - 64))
I have tried to increase the heap size up to 48k and reduce the heap size to 20k.
The malloc dead lock keeps the same. There is no improvement.
