I’m quite new to FreeRTOS and I would like to use it on an Atmel SAMB11 SoC (arm cortex M0), and more precisely on an Samb11Xplained board. For now I used provided example for SAMD21 SoC.
My first question is the following: does FreeRTOS port depends on the SoC (e.g. SAMB11) or only the processor (arm cortex M0) ? My understanding leads me to the second one.
Next, what are the steps to adapt an example to my board ?
Currently, I’m able to compile FreeRTOS sources in my project. I’ve first created only one task, and after starting the scheduler, the task was processing correctly (even though I observed that it doesn’t work if timer use is enabled in FreeRTOSConfig.h).
I am now trying to create two tasks and check that they both process. The problem is that only one task is executed. I suspect an issue with the systick timer but I don’t know how to fix it.
Then you are correct :o) FreeRTOS does not rely on anything outside of
the Cortex-M core unless you are going to write a port specific low
power tickless mode, in which case you need a clock source which is
external to the core.
The following links might help:
In your case adapting the SAMD20 demo might be your best option.
work if timer use is enabled in FreeRTOSConfig.h). I am now trying to
Have you installed the interrupt handlers? See the “special note for
ARM Cortex-M users” in bullet point #1 on this page of the FAQ:
Effectively I have seen this point. I tried different configurations without any success for now. Maybe I misunderstood how to set correctly these interrupt handlers.
Does the board clock configuration have an importance for FreeRTOS ? For example, basic code of SAMD20 in atmel studio have a specific function that configures the clock, but SAMB11 doesn’t seem to have one.
I initially thought it was already done somewhere, with SysTick_Handler handler…
With that configuration, I am able to execute two simple tasks concurrently.
BUT, atmel bluetooth sdk states that SAMB11 soc includes a proprietary RTOS which supports multiple tasks: Idle task, firmware task responsible for bluetooth functionnality, and application task (user application). So I guess FreeRTOS is not really compatible with this soc…
