FreeRtos not all tasks are running
I have a problem with threads. All of them are of same priority, with osDelay(300), except the uartThread which has osDelay(1). Everything else is the same for all threads. I have allocated 20k of HEAP and in ioc file it says im using only 3.5k so that should be fine i guess. However, only one of the threads is running (I2C_temp works fine besides the uartDATA), others never even enter the for(;:wink: loop. Any ideas?
So this is the freertos.c file where I create the tasks
/* USER CODE BEGIN Header */
 * File Name          : freertos.c
 * Description        : Code for freertos applications
 * @attention
 * Copyright (c) 2024 STMicroelectronics.
 * All rights reserved.
 * This software is licensed under terms that can be found in the LICENSE file
 * in the root directory of this software component.
 * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "FreeRTOS.h"
#include "task.h"
#include "main.h"
#include "cmsis_os.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "usart.h"
#include "i2c.h"
#include "spi.h"
#include "string.h"
#include "stepper.h"
#include <stdlib.h>
#include <stdio.h>
#include "stm32l4xx_it.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN Variables */
volatile char received_data;
volatile uint8_t commands;
e_UART_Status uartStatus = undefined;
/* USER CODE END Variables */
/* Definitions for stepper */
osThreadId_t stepperHandle;
const osThreadAttr_t stepper_attributes = {
    .name = "stepper",
    .stack_size = 128 * 4,
    .priority = (osPriority_t)osPriorityNormal,
/* Definitions for I2C_TempSens */
osThreadId_t I2C_TempSensHandle;
const osThreadAttr_t I2C_TempSens_attributes = {
    .name = "I2C_TempSens",
/* Definitions for SPI_TempSens */
osThreadId_t SPI_TempSensHandle;
const osThreadAttr_t SPI_TempSens_attributes = {
    .name = "SPI_TempSens",
/* Definitions for uart */
osThreadId_t uartHandle;
const osThreadAttr_t uart_attributes = {
    .name = "uart",
/* Definitions for uartQueue */
osMessageQueueId_t uartQueueHandle;
const osMessageQueueAttr_t uartQueue_attributes = {
    .name = "uartQueue"};
/* Definitions for Mutex1 */
osMutexId_t Mutex1Handle;
const osMutexAttr_t Mutex1_attributes = {
    .name = "Mutex1"};
/* Definitions for mutexStepper */
osMutexId_t mutexStepperHandle;
const osMutexAttr_t mutexStepper_attributes = {
    .name = "mutexStepper"};
/* Definitions for mutexUart */
osMutexId_t mutexUartHandle;
const osMutexAttr_t mutexUart_attributes = {
    .name = "mutexUart"};
/* Private function prototypes -----------------------------------------------*/
/* USER CODE BEGIN FunctionPrototypes */
/* USER CODE END FunctionPrototypes */
void StepperMotor(void *argument);
void I2C_temp(void *argument);
void SPI_temp(void *argument);
void uartDATA(void *argument);
void MX_FREERTOS_Init(void); /* (MISRA C 2004 rule 8.1) */
 * @brief  FreeRTOS initialization
 *   None
 * @retval None
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Create the mutex(es) */
  /* creation of Mutex1 */
  Mutex1Handle = osMutexNew(&Mutex1_attributes);
  /* creation of mutexStepper */
  mutexStepperHandle = osMutexNew(&mutexStepper_attributes);
  /* creation of mutexUart */
  mutexUartHandle = osMutexNew(&mutexUart_attributes);
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* Create the queue(s) */
  /* creation of uartQueue */
  uartQueueHandle = osMessageQueueNew(16, sizeof(uint16_t), &uartQueue_attributes);
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Create the thread(s) */
  /* creation of stepper */
  stepperHandle = osThreadNew(StepperMotor, NULL, &stepper_attributes);
  /* creation of I2C_TempSens */
  I2C_TempSensHandle = osThreadNew(I2C_temp, NULL, &I2C_TempSens_attributes);
  /* creation of SPI_TempSens */
  SPI_TempSensHandle = osThreadNew(SPI_temp, NULL, &SPI_TempSens_attributes);
  /* creation of uart */
  uartHandle = osThreadNew(uartDATA, NULL, &uart_attributes);
  /* USER CODE BEGIN RTOS_THREADS */
  /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* USER CODE BEGIN RTOS_EVENTS */
  /* add events, ... */
  /* USER CODE END RTOS_EVENTS */
And this are the tasks.
/* USER CODE END Header_StepperMotor */
  /* USER CODE BEGIN StepperMotor */
  char buffer[50];
  /* Infinite loop */
  for (;;)
    if (commandCheck() == set_stepper_OK)
      if (osMutexAcquire(mutexStepperHandle, portMAX_DELAY) == osOK)
        HAL_UART_Transmit(&huart1, "BUSY SET_STEPPER\n", 18, HAL_MAX_DELAY);
        motorRotation(motorInfo.motorNum, motorInfo.numOfSteps);
        HAL_UART_Transmit(&huart1, "OK SET_STEPPER\n", 16, HAL_MAX_DELAY);
        osMutexRelease(mutexStepperHandle);
        HAL_UART_Transmit(&huart1, "ERR\n", 5, HAL_MAX_DELAY);
    osDelay(300);
  /* USER CODE END StepperMotor */
/* USER CODE BEGIN Header_I2C_temp */
 * @brief Function implementing the mojTask thread.
 *  argument: Not used
 * @retval None
/* USER CODE END Header_I2C_temp */
  /* USER CODE BEGIN I2C_temp */
  float temp1;
  char buffer[12] = {0};
  char bufferTemp[10] = {0};
      UBaseType_t testtest;
    testtest = uxTaskGetNumberOfTasks();
  for (;;)
    if (uartStatus == get_temp_1_OK)
      temp1 = read_I2C();
      floatToString(temp1, buffer);
      HAL_UART_Transmit(&huart1, buffer, sizeof(buffer), HAL_MAX_DELAY);
    osDelay(300);
  /* USER CODE END I2C_temp */
/* USER CODE BEGIN Header_SPI_temp */
 * @brief Function implementing the SPI_TempSens thread.
 * @retval None
/* USER CODE END Header_SPI_temp */
  /* USER CODE BEGIN SPI_temp */
  float temp1, temp2;
  /* Infinite loop */
  for (;;)
    if (uartStatus == get_temp_2_OK)
      temp1 = read_SPI1();
    else if (uartStatus == get_temp_3_OK)
      temp2 = read_SPI2();
      floatToString(temp2, buffer);
    osDelay(300);
  /* USER CODE END SPI_temp */
/* USER CODE BEGIN Header_uartDATA */
 * @brief Function implementing the uart thread.
 * @retval None
/* USER CODE END Header_uartDATA */
  /* USER CODE BEGIN uartDATA */
  uint8_t cnt = 0;
  uint8_t temp;
  char buffer[50] = {'\0'};
  char msg = {0};
  char firstByte;
  __HAL_UART_CLEAR_FLAG(&huart1, UART_CLEAR_OREF);
  HAL_UART_Receive_IT(&huart1, (char *)&received_data, sizeof(received_data));
  /* Infinite loop */
  for (;;)
    if (osMessageQueueGet(uartQueueHandle, &msg, NULL, osWaitForever) == osOK)
      if (msg == '\r')
        buffer[0] = firstByte;
        parse_UART(buffer);
        memset(buffer, 0, sizeof(buffer));
        cnt = 0;
        uartStatus = commandCheck();
        osMessageQueueReset(uartQueueHandle);
        // commands = commandCheck();
      else if (msg == '\n')
      else if (cnt < (sizeof(buffer) - 1))
        buffer[cnt] = msg;
        cnt++;
      if (cnt == 1)
        firstByte = buffer[0];
    osDelay(1);
  /* USER CODE END uartDATA */
How did you verify that? It is possible that all those tasks are not getting unblocked. Can you put a log at the beginning (before entering for(;;)) to verify if tasks are starting at all?
So i found the solution. Even tho I used .ioc file to change the overall HEAP size, i did not allocate more heap to the threads. When I was using sprintf() the stack overflow happened. I manually increased stack size of the threads:
.name = “stepper”,
.stack_size = 256 * 4,
and now it works.
It never entered some threads because the stack overflew and messed things up.
