nobody wrote on Wednesday, September 06, 2006:
Nice one.
Nice one.
Thanks a lot. Changes are merged into my codebase. From what I found looking at the sourcecode and verifying myself:
- The counting variables was wrong.
- a vPortFree was missing for the TCB
- call to vTaskSuspend is no longer necessary.
Did I miss anything? I left the ASSERT statements in as well as the call to THREAD_INIT in the remove function because it makes debugging easier. For example if some function illegaly holds a pointer to the TCB.
Kind regards,
Christian Walter
rtel wrote on Wednesday, September 06, 2006:
I have not been able to keep up with this thread. Is there anything in the SAM7X demo in the FreeRTOS.org download that needs changing?
Thanks and regards.
I think the following code fragment is critical in sys_thread_new:
result = xTaskCreate( thread, ( signed portCHAR * ) “WEBSvr”, lwipBASIC_SERVER_STACK_SIZE, arg, prio, &CreatedTask );
// For each task created, store the task handle (pid) in the timers array.
// This scheme doesn’t allow for threads to be deleted
timeoutlist[nextthread++].pid = CreatedTask;
The problem in my opinion is that xTaskCreate might decide to switch the context and starts executing the thread ( at the bottom of xTaskCreate ). This happens when the priority of the caller is lower. In this case thread gets executed but its timeout list is not ready ( because the assignment comes later). This was the reason why I added a call to vTaskSuspendAll.
The next find I would like to point out is that most of the functions assume a TICK_RATE of 1000 because lwIP gives its arguments in microseconds. This is not a real problem and will propably not trigger a bug.
Kind regards,
Christian Walter
you have found all bug which I corrected. I commented the ASSERTs for my custom code but only for this moment until I don’t get full working freeRTOS+lwIP+ppp. Now it looks very nice.
I think interesting here is thread about -O flag for GNU GCC users.
Janusz
nobody wrote on Monday, September 11, 2006:
next little "bugs" in sys_arch.c:
//unsigned long
u32_t
sys_jiffies( void )
is the field char name[THREAD_NAME_LEN_MAX]; necessary in sys_tcb_t structure? I think it doesn’t bacuse you can use one variable in create task. What do you think about?
why did you use INIT_THREAD before free tcb in task remove?
it could be nice add to all asserts \r like everywhere…
ppp.c: __attribute__((naked)) for pppMain is good idea…
Janusz
1) Thanks a lot for the u32_t/unsigned long thing.
Status: Fixed in CVS
2) I added the name fields to make debugging easier for myself. I think we can remove them now because they waste memory.
Status: Fixed in CVS. Now uses stack space and the define configMAX_TASK_NAME_LEN from the FreeRTOS porting layer.
3) I always zero out variables which contain sensible information before passing them to free. This make sures that in case something else ( which in this case has a bug ) has a pointer to this memory I will notice it immediately. Maybe you can call it defensive programming. Again can be dropped for performance reasons.
Status: Not removed.
4) I removed all \r or \n characters in the strings because I think they should not be in the assert message. This is also now consistent with lwIP where also no newlines are in the statements.
5) The attribute is a good. The only thing to consider is that this will add a GCC dependency.
Status: Need to think about it how to do that in a portable way.
Thanks a lot for all your feedback,
Christian Walter
sorry for __attribute__((naked)) in ppp.c, it can cause the OS will crash!!! do not do it! I experiented that situation today.
Janusz
another hint in ppp.c
/* Remove this thread from the running ones. */
sys_arch_thread_remove( sys_arch_thread_current( ) );
LWIP_ASSERT( "pppMain: sys_arch_thread_remove did return\n", 0 );
is it good order the last two lines?
why did you comment /* PPPDEBUG((LOG_DEBUG, "pppMainWakeup: unit %d sio_read len=%d returned %d\n", pd, p->len, c)); */?
Janusz
Yes this is intended. If the remove works as expected this line is never executed. In case it is it is a bug. The context switch is made within TaskDelete in FreeRTOS after the task has been removed from the ready list.
I commented the pppMainWakeup because at 115200 and high speed a lot of CPU time was spent within this debug calls.
Christian
nobody wrote on Tuesday, September 12, 2006:
ok, thanks for the explanation.
Have you ever thought about #13315 bug: PPP PAP authentication can result in erroneous callbacks? I didn’t noticed this bug. I tried to comment line //if (u->us_clientstate == UPAPCS_AUTHREQ) /* Timeout pending? */ // JU - bug #13315 in upap_lowerdown(). I’m not sure whether the bug is indeed. What do you think about?
Janusz
hi,
I have checked. I made some tests with connection/disconnection process. I tested with pppd and GPRS modem.
results (with the same software):
- pppd without authorization - it is ok
- GPRS modem with pap authorization - after 2-3 reconnections there is NO FREE MBUFS! message. It is after MAGIC NUMBER and upap_lowerdown! So the bug exists I think.
solution:
- I have tried to comment the line like before but without any effect (maybe little better, more reconnection but nothing more)
- ??? I have not idea now.
Janusz
I did check the bug report but I think he stated in its report that the problem actually ist that the auth code accesses resources which are no longer available (because the LCP has shutdown).
I think a good start to verify this claim is to find all blocks where the auth code allocates memory and where they are freed again. Then add a print statement around them and put a breakpoint somewhere. Or maybe it is not in the AUTH but the other code lacks memory when AUTH is enabled. I did not have any time but I assume that the AUTH code runs in the same thread the PPP main itself, right?
I would love to work on this issue but sadly I am quite short on time.
Kind regards,
Christian Walter
nobody wrote on Wednesday, September 13, 2006:
You idea is very good. I have done that and now I am sure the reconnecting problem is inside ppp.c. pppInProc allocates pbuf’s but not always frees them! After about 5 reconnection wih 4000 lwIP cheap size you have NO FREE MBUFS message.
thanks a lot, I am still looking for the detail reason.
Janusz
ppp.c:
* ppp.c - Network Point to Point Protocol program file.
* Copyright (c) 2003 by Marc Boucher, Services Informatiques (MBSI) inc.
* portions Copyright (c) 1997 by Global Election Systems Inc.
* The authors hereby grant permission to use, copy, modify, distribute,
* and license this software and its documentation for any purpose, provided
* that existing copyright notices are retained in all copies and that this
* notice and the following disclaimer are included verbatim in any
* distributions. No written agreement, license, or royalty fee is required
* for any of the authorized uses.
* THIS SOFTWARE IS PROVIDED BY THE CONTRIBUTORS *AS IS* AND ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL THE CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* REVISION HISTORY
* 06-08-04 Christian Walter <wolti@sil.at>
* pppOpen code now checks if thread creation was successfull. If not returns
* an error.
* pppMain now correctly closes the thread if it exists.
* 03-01-01 Marc Boucher <marc@mbsi.ca>
* Ported to lwIP.
* 97-11-05 Guy Lancaster <lancasterg@acm.org>, Global Election Systems Inc.
* Original.
* ppp_defs.h - PPP definitions.
* if_pppvar.h - private structures and declarations for PPP.
* Copyright (c) 1994 The Australian National University.
* All rights reserved.
* Permission to use, copy, modify, and distribute this software and its
* documentation is hereby granted, provided that the above copyright
* notice appears in all copies. This software is provided without any
* warranty, express or implied. The Australian National University
* makes no representations about the suitability of this software for
* any purpose.
* IN NO EVENT SHALL THE AUSTRALIAN NATIONAL UNIVERSITY BE LIABLE TO ANY
* PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES
* ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
* THE AUSTRALIAN NATIONAL UNIVERSITY HAVE BEEN ADVISED OF THE POSSIBILITY
* OF SUCH DAMAGE.
* THE AUSTRALIAN NATIONAL UNIVERSITY SPECIFICALLY DISCLAIMS ANY WARRANTIES,
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
* AND FITNESS FOR A PARTICULAR PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS
* ON AN "AS IS" BASIS, AND THE AUSTRALIAN NATIONAL UNIVERSITY HAS NO
* OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS,
* OR MODIFICATIONS.
* if_ppp.h - Point-to-Point Protocol definitions.
* Copyright (c) 1989 Carnegie Mellon University.
* Redistribution and use in source and binary forms are permitted
* provided that the above copyright notice and this paragraph are
* duplicated in all such forms and that any documentation,
* advertising materials, and other materials related to such
* distribution and use acknowledge that the software was developed
* by Carnegie Mellon University. The name of the
* University may not be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED ``AS IS’’ AND WITHOUT ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
#include <string.h>
#include "ppp.h"
#if PPP_SUPPORT > 0
#include "randm.h"
#include "fsm.h"
#if PAP_SUPPORT > 0
#include "pap.h"
#if CHAP_SUPPORT > 0
#include "chap.h"
#include "ipcp.h"
#include "lcp.h"
#include "magic.h"
#include "auth.h"
#if VJ_SUPPORT > 0
#include "vj.h"
#include "pppdebug.h"
/*** LOCAL DEFINITIONS ***/
* The basic PPP frame.
#define PPP_ADDRESS(p) (((u_char *)(p))[0])
#define PPP_CONTROL(p) (((u_char *)(p))[1])
#define PPP_PROTOCOL(p) ((((u_char *)(p))[2] << 8) + ((u_char *)(p))[3])
/* PPP packet parser states. Current state indicates operation yet to be
* completed. */
typedef enum {
PDIDLE = 0, /* Idle state - waiting. */
PDSTART, /* Process start flag. */
PDADDRESS, /* Process address field. */
PDCONTROL, /* Process control field. */
PDPROTOCOL1, /* Process protocol field 1. */
PDPROTOCOL2, /* Process protocol field 2. */
PDDATA /* Process data byte. */
} PPPDevStates;
#define ESCAPE_P(accm, c) ((accm)[(c) >> 3] & pppACCMMask[c & 0x07])
/*** LOCAL DATA TYPES ***/
* PPP interface control block.
typedef struct PPPControl_s {
char openFlag; /* True when in use. */
char oldFrame; /* Old framing character for fd. */
sio_fd_t fd; /* File device ID of port. */
int kill_link; /* Shut the link down. */
int sig_hup; /* Carrier lost. */
int if_up; /* True when the interface is up. */
int errCode; /* Code indicating why interface is down. */
struct pbuf *inHead, *inTail; /* The input packet. */
PPPDevStates inState; /* The input process state. */
char inEscaped; /* Escape next character. */
u16_t inProtocol; /* The input protocol code. */
u16_t inFCS; /* Input Frame Check Sequence value. */
int mtu; /* Peer’s mru */
int pcomp; /* Does peer accept protocol compression? */
int accomp; /* Does peer accept addr/ctl compression? */
u_long lastXMit; /* Time of last transmission. */
ext_accm inACCM; /* Async-Ctl-Char-Map for input. */
ext_accm outACCM; /* Async-Ctl-Char-Map for output. */
#if VJ_SUPPORT > 0
int vjEnabled; /* Flag indicating VJ compression enabled. */
struct vjcompress vjComp; /* Van Jabobsen compression header. */
struct netif netif;
struct ppp_addrs addrs;
void (*linkStatusCB)(void *ctx, int errCode, void *arg);
void *linkStatusCtx;
} PPPControl;
* Ioctl definitions.
struct npioctl {
int protocol; /* PPP procotol, e.g. PPP_IP */
enum NPmode mode;
/*** LOCAL FUNCTION DECLARATIONS ***/
static void pppMain(void *pd);
static void pppDrop(PPPControl *pc);
static void pppInProc(int pd, u_char *s, int l);
/*** PUBLIC DATA STRUCTURES ***/
u_long subnetMask;
static PPPControl pppControl[NUM_PPP]; /* The PPP interface control blocks. */
* PPP Data Link Layer "protocol" table.
* One entry per supported protocol.
* The last entry must be NULL.
struct protent *ppp_protocols[] = {
&lcp_protent,
#if PAP_SUPPORT > 0
&pap_protent,
&chap_protent,
#if CBCP_SUPPORT > 0
&cbcp_protent,
&ipcp_protent,
#if CCP_SUPPORT > 0
&ccp_protent,
NULL
* Buffers for outgoing packets. This must be accessed only from the appropriate
* PPP task so that it doesn’t need to be protected to avoid collisions.
u_char outpacket_buf[NUM_PPP][PPP_MRU+PPP_HDRLEN];
/*** LOCAL DATA STRUCTURES ***/
* FCS lookup table as calculated by genfcstab.
static const u_short fcstab[256] = {
0x0000, 0x1189, 0x2312, 0x329b, 0x4624, 0x57ad, 0x6536, 0x74bf,
0x8c48, 0x9dc1, 0xaf5a, 0xbed3, 0xca6c, 0xdbe5, 0xe97e, 0xf8f7,
0x1081, 0x0108, 0x3393, 0x221a, 0x56a5, 0x472c, 0x75b7, 0x643e,
0x9cc9, 0x8d40, 0xbfdb, 0xae52, 0xdaed, 0xcb64, 0xf9ff, 0xe876,
0x2102, 0x308b, 0x0210, 0x1399, 0x6726, 0x76af, 0x4434, 0x55bd,
0xad4a, 0xbcc3, 0x8e58, 0x9fd1, 0xeb6e, 0xfae7, 0xc87c, 0xd9f5,
0x3183, 0x200a, 0x1291, 0x0318, 0x77a7, 0x662e, 0x54b5, 0x453c,
0xbdcb, 0xac42, 0x9ed9, 0x8f50, 0xfbef, 0xea66, 0xd8fd, 0xc974,
0x4204, 0x538d, 0x6116, 0x709f, 0x0420, 0x15a9, 0x2732, 0x36bb,
0xce4c, 0xdfc5, 0xed5e, 0xfcd7, 0x8868, 0x99e1, 0xab7a, 0xbaf3,
0x5285, 0x430c, 0x7197, 0x601e, 0x14a1, 0x0528, 0x37b3, 0x263a,
0xdecd, 0xcf44, 0xfddf, 0xec56, 0x98e9, 0x8960, 0xbbfb, 0xaa72,
0x6306, 0x728f, 0x4014, 0x519d, 0x2522, 0x34ab, 0x0630, 0x17b9,
0xef4e, 0xfec7, 0xcc5c, 0xddd5, 0xa96a, 0xb8e3, 0x8a78, 0x9bf1,
0x7387, 0x620e, 0x5095, 0x411c, 0x35a3, 0x242a, 0x16b1, 0x0738,
0xffcf, 0xee46, 0xdcdd, 0xcd54, 0xb9eb, 0xa862, 0x9af9, 0x8b70,
0x8408, 0x9581, 0xa71a, 0xb693, 0xc22c, 0xd3a5, 0xe13e, 0xf0b7,
0x0840, 0x19c9, 0x2b52, 0x3adb, 0x4e64, 0x5fed, 0x6d76, 0x7cff,
0x9489, 0x8500, 0xb79b, 0xa612, 0xd2ad, 0xc324, 0xf1bf, 0xe036,
0x18c1, 0x0948, 0x3bd3, 0x2a5a, 0x5ee5, 0x4f6c, 0x7df7, 0x6c7e,
0xa50a, 0xb483, 0x8618, 0x9791, 0xe32e, 0xf2a7, 0xc03c, 0xd1b5,
0x2942, 0x38cb, 0x0a50, 0x1bd9, 0x6f66, 0x7eef, 0x4c74, 0x5dfd,
0xb58b, 0xa402, 0x9699, 0x8710, 0xf3af, 0xe226, 0xd0bd, 0xc134,
0x39c3, 0x284a, 0x1ad1, 0x0b58, 0x7fe7, 0x6e6e, 0x5cf5, 0x4d7c,
0xc60c, 0xd785, 0xe51e, 0xf497, 0x8028, 0x91a1, 0xa33a, 0xb2b3,
0x4a44, 0x5bcd, 0x6956, 0x78df, 0x0c60, 0x1de9, 0x2f72, 0x3efb,
0xd68d, 0xc704, 0xf59f, 0xe416, 0x90a9, 0x8120, 0xb3bb, 0xa232,
0x5ac5, 0x4b4c, 0x79d7, 0x685e, 0x1ce1, 0x0d68, 0x3ff3, 0x2e7a,
0xe70e, 0xf687, 0xc41c, 0xd595, 0xa12a, 0xb0a3, 0x8238, 0x93b1,
0x6b46, 0x7acf, 0x4854, 0x59dd, 0x2d62, 0x3ceb, 0x0e70, 0x1ff9,
0xf78f, 0xe606, 0xd49d, 0xc514, 0xb1ab, 0xa022, 0x92b9, 0x8330,
0x7bc7, 0x6a4e, 0x58d5, 0x495c, 0x3de3, 0x2c6a, 0x1ef1, 0x0f78
/* PPP’s Asynchronous-Control-Character-Map. The mask array is used
* to select the specific bit for a character. */
static u_char pppACCMMask[] = {
0x01,
0x02,
0x04,
0x08,
0x10,
0x20,
0x40,
0x80
/*** PUBLIC FUNCTION DEFINITIONS ***/
/* Initialize the PPP subsystem. */
struct ppp_settings ppp_settings;
void pppInit(void)
struct protent *protp;
int i, j;
memset(&ppp_settings, 0, sizeof(ppp_settings));
ppp_settings.usepeerdns = 1;
pppSetAuth(PPPAUTHTYPE_NONE, NULL, NULL);
magicInit();
for (i = 0; i < NUM_PPP; i++) {
pppControl[i].openFlag = 0;
subnetMask = htonl(0xffffff00);
* Initialize to the standard option set.
for (j = 0; (protp = ppp_protocols[j]) != NULL; ++j)
(*protp->init)(i);
#if LINK_STATS
/* Clear the statistics. */
memset(&lwip_stats.link, 0, sizeof(lwip_stats.link));
void pppSetAuth(enum pppAuthType authType, const char *user, const char *passwd)
switch(authType) {
case PPPAUTHTYPE_NONE:
default:
#ifdef LWIP_PPP_STRICT_PAP_REJECT
ppp_settings.refuse_pap = 1;
#else
/* some providers request pap and accept an empty login/pw */
ppp_settings.refuse_pap = 0;
ppp_settings.refuse_chap = 1;
break;
case PPPAUTHTYPE_ANY:
/* Warning: Using PPPAUTHTYPE_ANY might have security consequences.
* RFC 1994 says:
* In practice, within or associated with each PPP server, there is a
* database which associates "user" names with authentication
* information ("secrets"). It is not anticipated that a particular
* named user would be authenticated by multiple methods. This would
* make the user vulnerable to attacks which negotiate the least secure
* method from among a set (such as PAP rather than CHAP). If the same
* secret was used, PAP would reveal the secret to be used later with
* CHAP.
* Instead, for each user name there should be an indication of exactly
* one method used to authenticate that user name. If a user needs to
* make use of different authentication methods under different
* circumstances, then distinct user names SHOULD be employed, each of
* which identifies exactly one authentication method.
ppp_settings.refuse_chap = 0;
break;
case PPPAUTHTYPE_PAP:
break;
case PPPAUTHTYPE_CHAP:
break;
if(user) {
strncpy(ppp_settings.user, user, sizeof(ppp_settings.user)-1);
ppp_settings.user[sizeof(ppp_settings.user)-1] = ‘\0’;
} else
ppp_settings.user[0] = ‘\0’;
if(passwd) {
strncpy(ppp_settings.passwd, passwd, sizeof(ppp_settings.passwd)-1);
ppp_settings.passwd[sizeof(ppp_settings.passwd)-1] = ‘\0’;
} else
ppp_settings.passwd[0] = ‘\0’;
/* Open a new PPP connection using the given I/O device.
* This initializes the PPP control block but does not
* attempt to negotiate the LCP session. If this port
* connects to a modem, the modem connection must be
* established before calling this.
* Return a new PPP connection descriptor on success or
* an error code (negative) on failure. */
int pppOpen(sio_fd_t fd, void (*linkStatusCB)(void *ctx, int errCode, void *arg), void *linkStatusCtx)
PPPControl *pc;
int pd;
/* Find a free PPP session descriptor. Critical region? */
for (pd = 0; pd < NUM_PPP && pppControl[pd].openFlag != 0; pd++);
if (pd >= NUM_PPP)
pd = PPPERR_OPEN;
pppControl[pd].openFlag = !0;
/* Launch a deamon thread. */
if (pd >= 0) {
pppControl[pd].openFlag = 1;
lcp_init(pd);
pc = &pppControl[pd];
pc->fd = fd;
pc->kill_link = 0;
pc->sig_hup = 0;
pc->if_up = 0;
pc->errCode = 0;
pc->inState = PDIDLE;
pc->inHead = NULL;
pc->inTail = NULL;
pc->inEscaped = 0;
pc->lastXMit = 0;
#if VJ_SUPPORT > 0
pc->vjEnabled = 0;
vj_compress_init(&pc->vjComp);
* Default the in and out accm so that escape and flag characters
* are always escaped.
memset(pc->inACCM, 0, sizeof(ext_accm));
pc->inACCM[15] = 0x60;
memset(pc->outACCM, 0, sizeof(ext_accm));
pc->outACCM[15] = 0x60;
pc->linkStatusCB = linkStatusCB;
pc->linkStatusCtx = linkStatusCtx;
if( sys_thread_new(pppMain, (void*)pd, PPP_THREAD_PRIO) != SYS_THREAD_NULL )
if(!linkStatusCB) {
while(pd >= 0 && !pc->if_up) {
sys_msleep(500);
if (lcp_phase[pd] == PHASE_DEAD) {
pppClose(pd);
if (pc->errCode)
pd = pc->errCode;
pd = PPPERR_CONNECT;
pc->openFlag = 0;
pd = PPPERR_ALLOC;
return pd;
/* Close a PPP connection and release the descriptor.
* Any outstanding packets in the queues are dropped.
* Return 0 on success, an error code on failure. */
int pppClose(int pd)
PPPControl *pc = &pppControl[pd];
int st = 0;
/* Disconnect */
pc->kill_link = !0;
pppMainWakeup(pd);
if(!pc->linkStatusCB) {
while(st >= 0 && lcp_phase[pd] != PHASE_DEAD) {
sys_msleep(500);
break;
return st;
/* This function is called when carrier is lost on the PPP channel. */
void pppSigHUP(int pd)
pc->sig_hup = 1;
pppMainWakeup(pd);
static void nPut(PPPControl *pc, struct pbuf *nb)
struct pbuf *b;
int c;
for(b = nb; b != NULL; b = b->next) {
if((c = sio_write(pc->fd, b->payload, b->len)) != b->len) {
PPPDEBUG((LOG_WARNING,
"PPP nPut: incomplete sio_write(%d, %u) = %d\n", pc->fd, b->len, c));
#if LINK_STATS
lwip_stats.link.err++;
#endif /* LINK_STATS */
pc->lastXMit = 0; /* prepend PPP_FLAG to next packet */
break;
PPPDEBUG((LOG_WARNING, "nPut: pbuf free %08x\n", nb)); //JU
pbuf_free(nb);
#if LINK_STATS
lwip_stats.link.xmit++;
* pppAppend - append given character to end of given pbuf. If outACCM
* is not NULL and the character needs to be escaped, do so.
* If pbuf is full, append another.
* Return the current pbuf.
static struct pbuf *pppAppend(u_char c, struct pbuf *nb, ext_accm *outACCM)
struct pbuf *tb = nb;
/* Make sure there is room for the character and an escape code.
* Sure we don’t quite fill the buffer if the character doesn’t
* get escaped but is one character worth complicating this? */
/* Note: We assume no packet header. */
if (nb && (PBUF_POOL_BUFSIZE - nb->len) < 2) {
tb = pbuf_alloc(PBUF_RAW, 0, PBUF_POOL);
PPPDEBUG((LOG_WARNING, “pppAppend: pbuf alloc %08x\n”, tb)); //JU
if (tb) {
nb->next = tb;
#if LINK_STATS
else {
lwip_stats.link.memerr++;
nb = tb;
if (nb) {
if (outACCM && ESCAPE_P(*outACCM, c)) {
*((u_char*)nb->payload + nb->len++) = PPP_ESCAPE;
*((u_char*)nb->payload + nb->len++) = c ^ PPP_TRANS;
*((u_char*)nb->payload + nb->len++) = c;
return tb;
/* Send a packet on the given connection. */
static err_t pppifOutput(struct netif *netif, struct pbuf *pb, struct ip_addr *ipaddr)
int pd = (int)netif->state;
u_short protocol = PPP_IP;
u_int fcsOut = PPP_INITFCS;
struct pbuf *headMB = NULL, *tailMB = NULL, *p;
u_char c;
(void)ipaddr;
/* Validate parameters. */
/* We let any protocol value go through - it can’t hurt us
* and the peer will just drop it if it’s not accepting it. */
if (pd < 0 || pd >= NUM_PPP || !pc->openFlag || !pb) {
PPPDEBUG((LOG_WARNING, “pppifOutput[%d]: bad parms prot=%d pb=%p\n”,
pd, protocol, pb));
#if LINK_STATS
lwip_stats.link.opterr++;
lwip_stats.link.drop++;
return ERR_ARG;
/* Check that the link is up. */
PPPDEBUG((LOG_ERR, "pppifOutput[%d]: link not up\n", pd));
#if LINK_STATS
lwip_stats.link.rterr++;
return ERR_RTE;
/* Grab an output buffer. */
headMB = pbuf_alloc(PBUF_RAW, 0, PBUF_POOL);
PPPDEBUG((LOG_WARNING, "pppifOutput: pbuf alloc %08x\n", headMB)); //JU
if (headMB == NULL) {
PPPDEBUG((LOG_WARNING, "pppifOutput[%d]: first alloc fail\n", pd));
#if LINK_STATS
return ERR_MEM;
#if VJ_SUPPORT > 0
* Attempt Van Jacobson header compression if VJ is configured and
* this is an IP packet.
if (protocol == PPP_IP && pc->vjEnabled) {
switch (vj_compress_tcp(&pc->vjComp, pb)) {
case TYPE_IP:
/* No change…
protocol = PPP_IP_PROTOCOL;
break;
case TYPE_COMPRESSED_TCP:
protocol = PPP_VJC_COMP;
break;
case TYPE_UNCOMPRESSED_TCP:
protocol = PPP_VJC_UNCOMP;
break;
default:
PPPDEBUG((LOG_WARNING, "pppifOutput[%d]: bad IP packet\n", pd));
#if LINK_STATS
lwip_stats.link.proterr++;
PPPDEBUG((LOG_WARNING, "pppifOutput: pbuf free %08x\n", headMB)); //JU
pbuf_free(headMB);
return ERR_VAL;
tailMB = headMB;
/* Build the PPP header. */
if ((sys_jiffies() - pc->lastXMit) >= PPP_MAXIDLEFLAG)
tailMB = pppAppend(PPP_FLAG, tailMB, NULL);
pc->lastXMit = sys_jiffies();
if (!pc->accomp) {
fcsOut = PPP_FCS(fcsOut, PPP_ALLSTATIONS);
tailMB = pppAppend(PPP_ALLSTATIONS, tailMB, &pc->outACCM);
fcsOut = PPP_FCS(fcsOut, PPP_UI);
tailMB = pppAppend(PPP_UI, tailMB, &pc->outACCM);
if (!pc->pcomp || protocol > 0xFF) {
c = (protocol >> 8) & 0xFF;
fcsOut = PPP_FCS(fcsOut, c);
tailMB = pppAppend(c, tailMB, &pc->outACCM);
c = protocol & 0xFF;
/* Load packet. */
for(p = pb; p; p = p->next) {
int n;
u_char *sPtr;
sPtr = (u_char*)p->payload;
n = p->len;
while (n-- > 0) {
c = *sPtr++;
/* Update FCS before checking for special characters. */
/* Copy to output buffer escaping special characters. */
/* Add FCS and trailing flag. */
c = ~fcsOut & 0xFF;
c = (~fcsOut >> 8) & 0xFF;
/* If we failed to complete the packet, throw it away. */
if (!tailMB) {
"pppifOutput[%d]: Alloc err - dropping proto=%d\n",
pd, protocol));
pbuf_free(headMB);
#if LINK_STATS
return ERR_MEM;
/* Send it. */
PPPDEBUG((LOG_INFO, "pppifOutput[%d]: proto=0x%04X\n", pd, protocol));
nPut(pc, headMB);
return ERR_OK;
/* Get and set parameters for the given connection.
int pppIOCtl(int pd, int cmd, void *arg)
int st = 0;
if (pd < 0 || pd >= NUM_PPP)
st = PPPERR_PARAM;
else {
switch(cmd) {
case PPPCTLG_UPSTATUS: /* Get the PPP up status. */
if (arg)
*(int *)arg = (int)(pc->if_up);
st = PPPERR_PARAM;
break;
case PPPCTLS_ERRCODE: /* Set the PPP error code. */
if (arg)
pc->errCode = *(int *)arg;
st = PPPERR_PARAM;
break;
case PPPCTLG_ERRCODE: /* Get the PPP error code. */
if (arg)
*(int *)arg = (int)(pc->errCode);
st = PPPERR_PARAM;
break;
case PPPCTLG_FD:
if (arg)
*(sio_fd_t *)arg = pc->fd;
st = PPPERR_PARAM;
break;
default:
st = PPPERR_PARAM;
break;
return st;
* Return the Maximum Transmission Unit for the given PPP connection.
u_int pppMTU(int pd)
u_int st;
if (pd < 0 || pd >= NUM_PPP || !pc->openFlag)
st = 0;
st = pc->mtu;
return st;
* Write n characters to a ppp link.
* RETURN: >= 0 Number of characters written
* -1 Failed to write to device
int pppWrite(int pd, const u_char *s, int n)
u_char c;
struct pbuf *headMB = NULL, *tailMB;
PPPDEBUG((LOG_WARNING, "pppWrite: pbuf alloc %08x\n", headMB)); //JU
#if LINK_STATS
return PPPERR_ALLOC;
tailMB = headMB;
/* If the link has been idle, we’ll send a fresh flag character to
* flush any noise. */
/* Load output buffer. */
while (n-- > 0) {
c = *s++;
c = ~fcsOut & 0xFF;
* Otherwise send it. */
if (!tailMB) {
“pppWrite[%d]: Alloc err - dropping pbuf len=%d\n”, pd, headMB->len));
/* “pppWrite[%d]: Alloc err - dropping %d:%.*H”, pd, headMB->len, LWIP_MIN(headMB->len * 2, 40), headMB->payload)); */
PPPDEBUG((LOG_WARNING, “pppWrite: pbuf free %08x\n”, headMB)); //JU
pbuf_free(headMB);
#if LINK_STATS
PPPDEBUG((LOG_INFO, "pppWrite[%d]: len=%d\n", pd, headMB->len));
/* "pppWrite[%d]: %d:%.*H", pd, headMB->len, LWIP_MIN(headMB->len * 2, 40), headMB->payload)); */
nPut(pc, headMB);
return PPPERR_NONE;
* ppp_send_config - configure the transmit characteristics of
* the ppp interface.
void ppp_send_config(
int unit,
int mtu,
u32_t asyncmap,
int pcomp,
int accomp
PPPControl *pc = &pppControl[unit];
int i;
pc->mtu = mtu;
pc->pcomp = pcomp;
pc->accomp = accomp;
/* Load the ACCM bits for the 32 control codes. */
for (i = 0; i < 32/8; i++)
pc->outACCM[i] = (u_char)((asyncmap >> (8 * i)) & 0xFF);
PPPDEBUG((LOG_INFO, "ppp_send_config[%d]: outACCM=%X %X %X %X\n",
unit,
pc->outACCM[0], pc->outACCM[1], pc->outACCM[2], pc->outACCM[3]));
* ppp_set_xaccm - set the extended transmit ACCM for the interface.
void ppp_set_xaccm(int unit, ext_accm *accm)
memcpy(pppControl[unit].outACCM, accm, sizeof(ext_accm));
PPPDEBUG((LOG_INFO, "ppp_set_xaccm[%d]: outACCM=%X %X %X %X\n",
unit,
pppControl[unit].outACCM[0],
pppControl[unit].outACCM[1],
pppControl[unit].outACCM[2],
pppControl[unit].outACCM[3]));
* ppp_recv_config - configure the receive-side characteristics of
void ppp_recv_config(
int unit,
int mru,
u32_t asyncmap,
int pcomp,
int accomp
int i;
(void)accomp;
(void)pcomp;
(void)mru;
for (i = 0; i < 32 / 8; i++)
pc->inACCM[i] = (u_char)(asyncmap >> (i * 8));
PPPDEBUG((LOG_INFO, "ppp_recv_config[%d]: inACCM=%X %X %X %X\n",
unit,
pc->inACCM[0], pc->inACCM[1], pc->inACCM[2], pc->inACCM[3]));
#if 0
* ccp_test - ask kernel whether a given compression method
* is acceptable for use. Returns 1 if the method and parameters
* are OK, 0 if the method is known but the parameters are not OK
* (e.g. code size should be reduced), or -1 if the method is unknown.
int ccp_test(
int unit,
int opt_len,
int for_transmit,
u_char *opt_ptr
return 0; /* XXX Currently no compression. */
* ccp_flags_set - inform kernel about the current state of CCP.
void ccp_flags_set(int unit, int isopen, int isup)
/* XXX */
* ccp_fatal_error - returns 1 if decompression was disabled as a
* result of an error detected after decompression of a packet,
* 0 otherwise. This is necessary because of patent nonsense.
int ccp_fatal_error(int unit)
/* XXX */
return 0;
* get_idle_time - return how long the link has been idle.
int get_idle_time(int u, struct ppp_idle *ip)
/* XXX */
(void)u;
(void)ip;
return 0;
* Return user specified netmask, modified by any mask we might determine
* for address `addr’ (in network byte order).
* Here we scan through the system’s list of interfaces, looking for
* any non-point-to-point interfaces which might appear to be on the same
* network as `addr’. If we find any, we OR in their netmask to the
* user-specified netmask.
u32_t GetMask(u32_t addr)
u32_t mask, nmask;
htonl(addr);
if (IN_CLASSA(addr)) /* determine network mask for address class */
nmask = IN_CLASSA_NET;
else if (IN_CLASSB(addr))
nmask = IN_CLASSB_NET;
nmask = IN_CLASSC_NET;
/* class D nets are disallowed by bad_ip_adrs */
mask = subnetMask | htonl(nmask);
/* XXX
* Scan through the system’s network interfaces.
* Get each netmask and OR them into our mask.
return mask;
* sifvjcomp - config tcp header compression
int sifvjcomp(
int pd,
int vjcomp,
int cidcomp,
int maxcid
#if VJ_SUPPORT > 0
pc->vjEnabled = vjcomp;
pc->vjComp.compressSlot = cidcomp;
pc->vjComp.maxSlotIndex = maxcid;
PPPDEBUG((LOG_INFO, "sifvjcomp: VJ compress enable=%d slot=%d max slot=%d\n",
vjcomp, cidcomp, maxcid));
return 0;
* pppifNetifInit - netif init callback
static err_t pppifNetifInit(struct netif *netif)
netif->name[0] = ‘p’;
netif->name[1] = ‘p’;
netif->output = pppifOutput;
netif->mtu = pppMTU((int)netif->state);
return ERR_OK;
* sifup - Config the interface up and enable IP packets to pass.
int sifup(int pd)
int st = 1;
if (pd < 0 || pd >= NUM_PPP || !pc->openFlag) {
st = 0;
PPPDEBUG((LOG_WARNING, "sifup[%d]: bad parms\n", pd));
} else {
netif_remove(&pc->netif);
if (netif_add(&pc->netif, &pc->addrs.our_ipaddr, &pc->addrs.netmask, &pc->addrs.his_ipaddr, (void *)pd, pppifNetifInit, ip_input)) {
pc->if_up = 1;
pc->errCode = PPPERR_NONE;
/* bug #16602 */
netif_set_up( &pc->netif );
PPPDEBUG((LOG_DEBUG, "sifup: unit %d: linkStatusCB=%lx errCode=%d\n", pd, pc->linkStatusCB, pc->errCode));
if(pc->linkStatusCB)
pc->linkStatusCB(pc->linkStatusCtx, pc->errCode, &pc->addrs);
} else {
st = 0;
PPPDEBUG((LOG_ERR, "sifup[%d]: netif_add failed\n", pd));
return st;
* sifnpmode - Set the mode for handling packets for a given NP.
int sifnpmode(int u, int proto, enum NPmode mode)
(void)u;
(void)proto;
(void)mode;
return 0;
* sifdown - Config the interface down and disable IP.
int sifdown(int pd)
int st = 1;
st = 0;
PPPDEBUG((LOG_WARNING, "sifdown[%d]: bad parms\n", pd));
} else {
pc->if_up = 0;
PPPDEBUG((LOG_DEBUG, "sifdown: unit %d: linkStatusCB=%lx errCode=%d\n", pd, pc->linkStatusCB, pc->errCode));
pc->linkStatusCB(pc->linkStatusCtx, PPPERR_CONNECT, NULL);
return st;
* sifaddr - Config the interface IP addresses and netmask.
int sifaddr(
int pd, /* Interface unit ??? */
u32_t o, /* Our IP address ??? */
u32_t h, /* His IP address ??? */
u32_t m, /* IP subnet mask ??? */
u32_t ns1, /* Primary DNS */
u32_t ns2 /* Secondary DNS */
int st = 1;
st = 0;
} else {
memcpy(&pc->addrs.our_ipaddr, &o, sizeof(o));
memcpy(&pc->addrs.his_ipaddr, &h, sizeof(h));
memcpy(&pc->addrs.netmask, &m, sizeof(m));
memcpy(&pc->addrs.dns1, &ns1, sizeof(ns1));
memcpy(&pc->addrs.dns2, &ns2, sizeof(ns2));
return st;
* cifaddr - Clear the interface IP addresses, and delete routes
* through the interface if possible.
int cifaddr(
u32_t h /* IP broadcast address ??? */
int st = 1;
(void)o;
(void)h;
st = 0;
} else {
IP4_ADDR(&pc->addrs.our_ipaddr, 0,0,0,0);
IP4_ADDR(&pc->addrs.his_ipaddr, 0,0,0,0);
IP4_ADDR(&pc->addrs.netmask, 255,255,255,0);
IP4_ADDR(&pc->addrs.dns1, 0,0,0,0);
IP4_ADDR(&pc->addrs.dns2, 0,0,0,0);
return st;
* sifdefaultroute - assign a default route through the address given.
int sifdefaultroute(int pd, u32_t l, u32_t g)
int st = 1;
(void)l;
(void)g;
st = 0;
} else {
netif_set_default(&pc->netif);
/* TODO: check how PPP handled the netMask, previously not set by ipSetDefault */
return st;
* cifdefaultroute - delete a default route through the address given.
int cifdefaultroute(int pd, u32_t l, u32_t g)
int st = 1;
(void)l;
(void)g;
st = 0;
} else {
netif_set_default(NULL);
return st;
void
pppMainWakeup(int pd)
PPPDEBUG((LOG_DEBUG, "pppMainWakeup: unit %d\n", pd));
sio_read_abort( pppControl[pd].fd );
/* these callbacks are necessary because lcp_* functions
must be called in the same context as pppInput(),
namely the tcpip_thread(), essentially because
they manipulate timeouts which are thread-private
static void
pppStartCB(void *arg)
int pd = (int)arg;
PPPDEBUG((LOG_DEBUG, "pppStartCB: unit %d\n", pd));
lcp_lowerup(pd);
lcp_open(pd); /* Start protocol */
static void
pppStopCB(void *arg)
int pd = (int)arg;
PPPDEBUG((LOG_DEBUG, "pppStopCB: unit %d\n", pd));
lcp_close(pd, "User request");
static void
pppHupCB(void *arg)
int pd = (int)arg;
PPPDEBUG((LOG_DEBUG, "pppHupCB: unit %d\n", pd));
lcp_lowerdown(pd);
link_terminated(pd);
/*** LOCAL FUNCTION DEFINITIONS ***/
/* The main PPP process function. This implements the state machine according
* to section 4 of RFC 1661: The Point-To-Point Protocol. */
static void pppMain(void *arg)
err_t err;
int pd = (int)arg;
struct pbuf *p;
PPPControl* pc;
p = pbuf_alloc(PBUF_RAW, PPP_MRU+PPP_HDRLEN, PBUF_RAM);
PPPDEBUG((LOG_WARNING, "pppMain: pbuf alloc %08x\n", p)); //JU
if(!p) {
LWIP_ASSERT("p != NULL", p);
pc->errCode = PPPERR_ALLOC;
goto out;
* Start the connection and handle incoming events (packet or timeout).
PPPDEBUG((LOG_INFO, “pppMain: unit %d: Connecting\n”, pd));
err = tcpip_callback(pppStartCB, arg);
LWIP_ASSERT( “pppMain: can’t install callback handler\n”, err == ERR_OK );
while (lcp_phase[pd] != PHASE_DEAD) {
if (pc->kill_link) {
PPPDEBUG((LOG_DEBUG, “pppMainWakeup: unit %d kill_link -> pppStopCB\n”, pd));
pc->errCode = PPPERR_USER;
/* This will leave us at PHASE_DEAD. */
tcpip_callback(pppStopCB, arg);
pc->kill_link = 0;
else if (pc->sig_hup) {
PPPDEBUG((LOG_DEBUG, “pppMainWakeup: unit %d sig_hup -> pppHupCB\n”, pd));
pc->sig_hup = 0;
tcpip_callback(pppHupCB, arg);
} else {
int c = sio_read(pc->fd, p->payload, p->len);
if(c > 0) {
pppInProc(pd, p->payload, c);
} else {
/* PPPDEBUG((LOG_DEBUG, “pppMainWakeup: unit %d sio_read len=%d returned %d\n”, pd, p->len, c)); */
PPPDEBUG((LOG_INFO, “pppMain: unit %d: PHASE_D EAD\n”, pd));
PPPDEBUG((LOG_WARNING, “pppMain: pbuf free %08x\n”, p)); //JU
pbuf_free(p);
out:
PPPDEBUG((LOG_DEBUG, "pppMain: unit %d: linkStatusCB=%lx errCode=%d\n", pd, pc->linkStatusCB, pc->errCode));
pc->linkStatusCB(pc->linkStatusCtx, pc->errCode ? pc->errCode : PPPERR_PROTOCOL, NULL);
pc->openFlag = 0;
static struct pbuf *pppSingleBuf(struct pbuf *p)
struct pbuf *q, *b;
u_char *pl;
if(p->tot_len == p->len)
return p;
q = pbuf_alloc(PBUF_RAW, p->tot_len, PBUF_RAM);
PPPDEBUG((LOG_WARNING, "pppSingleBuf: pbuf alloc %08x\n", q)); //JU
if(!q) {
PPPDEBUG((LOG_ERR,
"pppSingleBuf: unable to alloc new buf (%d)\n", p->tot_len));
return p; /* live dangerously */
for(b = p, pl = q->payload; b != NULL; b = b->next) {
memcpy(pl, b->payload, b->len);
pl += b->len;
PPPDEBUG((LOG_WARNING, "pppSingleBuf: pbuf free %08x\n", p)); //JU
pbuf_free(p);
return q;
struct pppInputHeader {
int unit;
u16_t proto;
* Pass the processed input packet to the appropriate handler.
* This function and all handlers run in the context of the tcpip_thread
static void pppInput(void *arg)
struct pbuf *nb = (struct pbuf *)arg;
u16_t protocol;
int pd;
pd = ((struct pppInputHeader *)nb->payload)->unit;
protocol = ((struct pppInputHeader *)nb->payload)->proto;
pbuf_header(nb, -(int)sizeof(struct pppInputHeader));
#if LINK_STATS
lwip_stats.link.recv++;
* Toss all non-LCP packets unless LCP is OPEN.
* Until we get past the authentication phase, toss all packets
* except LCP, LQR and authentication packets.
if((lcp_phase[pd] <= PHASE_AUTHENTICATE) && (protocol != PPP_LCP)) {
if(!((protocol == PPP_LQR) || (protocol == PPP_PAP) || (protocol == PPP_CHAP)) ||
(lcp_phase[pd] != PHASE_AUTHENTICATE)) {
PPPDEBUG((LOG_INFO, "pppInput: discarding proto 0x%04X in phase %d\n", protocol, lcp_phase[pd]));
goto drop;
switch(protocol) {
case PPP_VJC_COMP: /* VJ compressed TCP */
#if VJ_SUPPORT > 0
PPPDEBUG((LOG_INFO, “pppInput[%d]: vj_comp in pbuf len=%d\n”, pd, nb->len));
* Clip off the VJ header and prepend the rebuilt TCP/IP header and
* pass the result to IP.
if (vj_uncompress_tcp(&nb, &pppControl[pd].vjComp) >= 0) {
pppControl[pd].netif.input(nb, &pppControl[pd].netif);
return;
/* Something’s wrong so drop it. */
PPPDEBUG((LOG_WARNING, “pppInput[%d]: Dropping VJ compressed\n”, pd));
#else
/* No handler for this protocol so drop the packet. */
PPPDEBUG((LOG_INFO, “pppInput[%d]: drop VJ Comp in %d:%s\n”, pd, nb->len, nb->payload));
#endif /* VJ_SUPPORT > 0 */
break;
case PPP_VJC_UNCOMP: /* VJ uncompressed TCP */
#if VJ_SUPPORT > 0
PPPDEBUG((LOG_INFO, “pppInput[%d]: vj_un in pbuf len=%d\n”, pd, nb->len));
* Process the TCP/IP header for VJ header compression and then pass
* the packet to IP.
if (vj_uncompress_uncomp(nb, &pppControl[pd].vjComp) >= 0) {
return;
PPPDEBUG((LOG_WARNING, “pppInput[%d]: Dropping VJ uncompressed\n”, pd));
#else
PPPDEBUG((LOG_INFO,
“pppInput[%d]: drop VJ UnComp in %d:.*H\n”,
pd, nb->len, LWIP_MIN(nb->len * 2, 40), nb->payload));
break;
case PPP_IP: /* Internet Protocol */
PPPDEBUG((LOG_INFO, “pppInput[%d]: ip in pbuf len=%d\n”, pd, nb->len));
return;
default:
int i;
* Upcall the proper protocol input routine.
for (i = 0; (protp = ppp_protocols[i]) != NULL; ++i) {
if (protp->protocol == protocol && protp->enabled_flag) {
PPPDEBUG((LOG_INFO, "pppInput[%d]: %s len=%d\n", pd, protp->name, nb->len));
nb = pppSingleBuf(nb);
(*protp->input)(pd, nb->payload, nb->len);
goto out;
/* No handler for this protocol so reject the packet. */
PPPDEBUG((LOG_INFO, "pppInput[%d]: rejecting unsupported proto 0x%04X len=%d\n", pd, protocol, nb->len));
pbuf_header(nb, sizeof(protocol));
#if BYTE_ORDER == LITTLE_ENDIAN
protocol = htons(protocol);
memcpy(nb->payload, &protocol, sizeof(protocol));
lcp_sprotrej(pd, nb->payload, nb->len);
break;
drop:
#if LINK_STATS
out:
PPPDEBUG((LOG_WARNING, "pppInput: pbuf free %08x\n", nb)); //JU
pbuf_free(nb);
return;
* Drop the input packet.
if (pc->inHead != NULL) {
#if 0
PPPDEBUG((LOG_INFO, "pppDrop: %d:%.*H\n", pc->inHead->len, min(60, pc->inHead->len * 2), pc->inHead->payload));
PPPDEBUG((LOG_INFO, "pppDrop: pbuf len=%d\n", pc->inHead->len));
if (pc->inTail && (pc->inTail != pc->inHead))
PPPDEBUG((LOG_WARNING, "pppDrop: pbuf free %08x & %08x\n", pc->inTail, pc->inHead)); //JU
pbuf_free(pc->inTail);
pbuf_free(pc->inHead);
pc->inHead = NULL;
pc->inTail = NULL;
#if VJ_SUPPORT > 0
vj_uncompress_err(&pc->vjComp);
#if LINK_STATS
* Process a received octet string.
struct pbuf *nextNBuf;
u_char curChar;
PPPDEBUG((LOG_DEBUG, “pppInProc[%d]: got %d bytes\n”, pd, l));
while (l-- > 0) {
curChar = *s++;
/* Handle special characters. */
if (ESCAPE_P(pc->inACCM, curChar)) {
/* Check for escape sequences. */
/* XXX Note that this does not handle an escaped 0x5d character which
* would appear as an escape character. Since this is an ASCII ‘]’
* and there is no reason that I know of to escape it, I won’t complicate
* the code to handle this case. GLL */
if (curChar == PPP_ESCAPE)
pc->inEscaped = 1;
/* Check for the flag character. */
else if (curChar == PPP_FLAG) {
/* If this is just an extra flag character, ignore it. */
if (pc->inState <= PDADDRESS)
/* If we haven’t received the packet header, drop what has come in. */
else if (pc->inState < PDDATA) {
“pppInProc[%d]: Dropping incomplete packet %d\n”,
pd, pc->inState));
#if LINK_STATS
lwip_stats.link.lenerr++;
pppDrop(pc);
/* If the fcs is invalid, drop the packet. */
else if (pc->inFCS != PPP_GOODFCS) {
PPPDEBUG((LOG_INFO,
“pppInProc[%d]: Dropping bad fcs 0x%04X proto=0x%04X\n”,
pd, pc->inFCS, pc->inProtocol));
#if LINK_STATS
lwip_stats.link.chkerr++;
pppDrop(pc);
/* Otherwise it’s a good packet so pass it on. */
else {
/* Trim off the checksum. */
if(pc->inTail->len >= 2) {
pc->inTail->len -= 2;
pc->inTail->tot_len = pc->inTail->len;
if (pc->inTail != pc->inHead) {
pbuf_cat(pc->inHead, pc->inTail);
} else {
pbuf_realloc(pc->inHead, pc->inHead->tot_len - 2);
/* Dispatch the packet thereby consuming it. */
if(tcpip_callback(pppInput, pc->inHead) != ERR_OK) {
PPPDEBUG((LOG_ERR,
“pppInProc[%d]: tcpip_callback() failed, dropping packet\n”, pd));
PPPDEBUG((LOG_WARNING, “pppInProc: pbuf free %08x\n”, pc->inHead)); //JU
#if LINK_STATS
pc->inHead = NULL;
pc->inTail = NULL;
/* Prepare for a new packet. */
pc->inFCS = PPP_INITFCS;
pc->inState = PDADDRESS;
pc->inEscaped = 0;
/* Other characters are usually control characters that may have
* been inserted by the physical layer so here we just drop them. */
else {
“pppInProc[%d]: Dropping ACCM char <%d>\n”, pd, curChar));
/* Process other characters. */
else {
/* Unencode escaped characters. */
if (pc->inEscaped) {
pc->inEscaped = 0;
curChar ^= PPP_TRANS;
/* Process character relative to current state. */
switch(pc->inState) {
case PDIDLE: /* Idle state - waiting. */
/* Drop the character if it’s not 0xff
* we would have processed a flag character above. */
if (curChar != PPP_ALLSTATIONS) {
break;
/* Fall through */
case PDSTART: /* Process start flag. */
/* Fall through */
case PDADDRESS: /* Process address field. */
if (curChar == PPP_ALLSTATIONS) {
pc->inState = PDCONTROL;
break;
/* Else assume compressed address and control fields so
* fall through to get the protocol… */
case PDCONTROL: /* Process control field. */
/* If we don’t get a valid control code, restart. */
if (curChar == PPP_UI) {
pc->inState = PDPROTOCOL1;
break;
#if 0
else {
“pppInProc[%d]: Invalid control <%d>\n”, pd, curChar));
pc->inState = PDSTART;
case PDPROTOCOL1: /* Process protocol field 1. */
/* If the lower bit is set, this is the end of the protocol
* field. */
if (curChar & 1) {
pc->inProtocol = curChar;
pc->inState = PDDATA;
else {
pc->inProtocol = (u_int)curChar << 8;
pc->inState = PDPROTOCOL2;
break;
case PDPROTOCOL2: /* Process protocol field 2. */
pc->inProtocol |= curChar;
break;
case PDDATA: /* Process data byte. */
/* Make space to receive processed data. */
if (pc->inTail == NULL || pc->inTail->len == PBUF_POOL_BUFSIZE) {
if(pc->inTail) {
/* If we haven’t started a packet, we need a packet header. */
nextNBuf = pbuf_alloc(PBUF_RAW, 0, PBUF_POOL);
PPPDEBUG((LOG_WARNING, “pppInProc: pbuf alloc %08x\n”, nextNBuf)); //JU
if (nextNBuf == NULL) {
/* No free buffers. Drop the input packet and let the
* higher layers deal with it. Continue processing
* the received pbuf chain in case a new packet starts. */
PPPDEBUG((LOG_ERR, “pppInProc[%d]: NO FREE MBUFS!\n”, pd));
#if LINK_STATS
pppDrop(pc);
pc->inState = PDSTART; /* Wait for flag sequence. */
break;
if (pc->inHead == NULL) {
struct pppInputHeader *pih = nextNBuf->payload;
pih->unit = pd;
pih->proto = pc->inProtocol;
nextNBuf->len += sizeof(*pih);
pc->inHead = nextNBuf;
pc->inTail = nextNBuf;
/* Load character into buffer. */
((u_char*)pc->inTail->payload)[pc->inTail->len++] = curChar;
break;
/* update the frame check sequence number. */
pc->inFCS = PPP_FCS(pc->inFCS, curChar);
avRandomize();
#endif /* PPP_SUPPORT */
debug output (after some pppClose and pppSigHUP):
dbg uart ok
lcp_init: xmit_accm=0 0 0 0
upap_init: 0
at
at
sys_arch_timeouts: ptask != NULL
http serv lev 0b
tcp_bind: bind to port 80
http serv lev 3
ate0
pin entering
free heap: 5632
connecting…
ppp starting 1 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppMain: pbuf alloc 00205b58
pppMain: unit 0: Connecting
pppStartCB: unit 0
ppp_set_xaccm[0]: outACCM=0 0 0 0
ppp_send_config[0]: outACCM=FF FF FF FF
ppp_recv_config[0]: inACCM=0 0 0 0
lcp_lowerup: asyncmap=0 0 0 0
LCP: lowerup state 0 -> 2
auth_reset: 0
lcp_addci: L opt=2 0
lcp_addci: L opt=5 52181044
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite: pbuf alloc 0020791c
pppWrite[0]: len=47
nPut: pbuf free 0020791c
fsm_sdata(LCP): Sent code 1,1,20.
LCP: sending Configure-Request, id 1
LCP: open state 2 -> 6
pppInProc[0]: got 100 bytes
pppInProc: pbuf alloc 0020791c
pppInput[0]: LCP len=24
fsm_input(LCP):1,3,24
fsm_rconfreq(LCP): Rcvd id 3 state=6
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (69C92C) PCOMPRESSION
lcp_reqci: ACCOMPRESSION
lcp_reqci: returning CONFACK.
pppWrite: pbuf alloc 00207f08
pppWrite[0]: len=52
nPut: pbuf free 00207f08
fsm_sdata(LCP): Sent code 2,3,24.
pppInput: pbuf free 0020791c
pppInProc[0]: got 2 bytes
pppInProc[0]: Dropping bad fcs 0x7207 proto=0xC021
pppDrop: pbuf len=17
pppDrop: pbuf free 0020791c & 0020791c
pppInProc[0]: got 52 bytes
fsm_input(LCP):1,2,24
fsm_rconfreq(LCP): Rcvd id 2 state=8
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6A6E14) PCOMPRESSION
pppWrite[0]: len=53
fsm_sdata(LCP): Sent code 2,2,24.
LCP: timeout resending Config-Request state=8
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=47
pppInProc[0]: got 35 bytes
pppInProc[0]: got 64 bytes
pppInput[0]: LCP len=20
fsm_input(LCP):2,1,20
fsm_rconfack(LCP): Rcvd id 1 state=8
lcp_acki: Ack
ppp_send_config[0]: outACCM=0 0 0 0
link_established: 0
upap_lowerup: 0 s=0
IPCP: lowerup state 0 -> 2
upap_authwithpeer: 0 user=none password=none s=1
pppWrite[0]: len=22
pap_sauth: Sent id 1
pppInProc: pbuf alloc 0020791c <= possible the memory leak!!!
fsm_input(LCP):1,1,24
fsm_rconfreq(LCP): Rcvd id 1 state=9
link_down: 0
upap_lowerdown: 0 s=3
IPCP: lowerdown state 2 -> 0
IPCP: close reason=LCP down state 0 -> 0
pppMainWakeup: unit 0
ppp_recv_config[0]: iupap_timeout: 0 timeout 6 expired s=4
IPCP: timeout resending Config-Request state=6
pppWrite[0]: len=30
fsm_sdata(IPCP): Sent code 1,1,22.
IPCP: sending Configure-Request, id 1
pppInProc[0]: got 28 bytes
pppInProc: pbuf alloc 0020791c <= I can’t understand that
pppInput[0]: IPCP len=22
fsm_input(IPCP):3,1,22
fsm_rconfnakrej(IPCP): Rcvd id 1 state=6
local IP address 172.23.27.231
primary DNS address 212.2.96.51
secondary DNS address 212.2.96.52
pppWrite[0]: len=29
fsm_sdata(IPCP): Sent code 1,2,22.
IPCP: sending Configure-Request, id 2
pppInProc[0]: got 44 bytes
fsm_input(IPCP):2,2,22
fsm_rconfack(IPCP): Rcvd id 2 state=6
pppInput[0]: IPCP len=10
fsm_input(IPCP):1,2,10
fsm_rconfreq(IPCP): Rcvd id 2 state=7
ipcp_reqci: ADDR 192.168.100.101
ipcp_reqci: returning Configure-ACK
pppWrite[0]: len=18
fsm_sdata(IPCP): Sent code 2,2,10.
np_up: 0 proto=21
np_up: maxconnect=0 idle_time_limit=0
ipcp: up
sifup: unit 0: linkStatusCB=10911d errCode=0
connected
adr our: 172.23.27.231 ip: 192.168.100.101 mask: 255.255.255.0
dns1: 212.2.96.51 dns2: 212.2.96.52
remote IP address 192.168.100.101
free heap: 1416
disconnecting by closing…
pppMainWakeup: unit 0 kill_link -> pppStopCB
pppStopCB: unit 0
link_down: 0
upap_lowerdown: 0 s=4
ipcp: down
np_down: 0 proto=21
sifdown: unit 0: linkStatusCB=10911d errCode=-5
error: -6
IPCP: lowerdown state 9 -> 1
IPCP: close reason=LCP down state 1 -> 0
pppWrite[0]: len=29
fsm_sdata(LCP): Sent code 5,3,16.
LCP: close reason=User request state 9 -> 4
free heap: 1416
pppInProc[0]: got 29 bytes
pppInput[0]: LCP len=16
fsm_input(LCP):6,3,16
fsm_rtermack(LCP): state=4
link_terminated: 0
Connection terminated.
pppMain: unit 0: PHASE_DEAD
pppMain: pbuf free 00205b58
pppMain: unit 0: linkStatusCB=10911d errCode=-5
error: -5
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
ppp starting 2 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 99208214
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInput[0]: LCP len=14
fsm_input(LCP):5,3,14
fsm_rtermreq(LCP): Rcvd id 3 state=6
pppWrite[0]: len=16
fsm_sdata(LCP): Sent code 6,3,4.
pppInProc: pbuf alloc 0020791c <= here is the leak!!!
LCP: timeout resending Config-Request state=6
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
LCP: timeout sending Config-Requests state=6
link_terminated: 0
pppMain: unit 0: linkStatusCB=10911d errCode=0
error: -8
free heap: 1444
free heap: 1444
connecting…
ppp starting 3 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 3D3054FA
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc: pbuf alloc 00207f08
fsm_rconfreq(LCP): Rcvd id 1 state=6
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6C6260) PCOMPRESSION
pppWrite: pbuf alloc 002084f4
pppWrite[0]: len=51
nPut: pbuf free 002084f4
fsm_sdata(LCP): Sent code 2,1,24.
pppInput: pbuf free 00207f08
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc[0]: got 33 bytes
pppInProc[0]: Dropping bad fcs 0x290B proto=0xC021
pppDrop: pbuf len=25
pppDrop: pbuf free 00207f08 & 00207f08
pppInProc[0]: got 65 bytes
lcp_acki: Ack
link_established: 0
upap_lowerup: 0 s=0
pppWrite[0]: len=22
pap_sauth: Sent id 3
link_down: 0
auth_reset: 0
lcp_addci: L opt=5 37B3E401
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
fsm_sdata(LCP): Sent code 1,2,20.
LCP: sending Configure-Request, id 2
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6C7A94) PCOMPRESSION
pppWrite[0]: len=52
pppInProc[0]: got 46 bytes
fsm_input(LCP):2,2,20
fsm_rconfack(LCP): Rcvd id 2 state=8
lcp_acki: Ack
link_established: 0
upap_lowerup: 0 s=0
pppWrite[0]: len=21
pap_sauth: Sent id 4
pppInProc[0]: got 11 bytes
pppInput[0]: PAP len=5
pap_rauthack: Rcvd id 4 s=3
Remote message:
auth_withpeer_success: 0 proto=C023
pppWrite[0]: len=29
fsm_sdata(IPCP): Sent code 1,3,22.
IPCP: sending Configure-Request, id 3
IPCP: open statupap_timeout: 0 timeout 6 expired s=4
pppWrite[0]: len=30
fsm_input(IPCP):3,3,22
fsm_rconfnakrej(IPCP): Rcvd id 3 state=6
local IP address 172.24.167.88
pppWrite[0]: len=29
fsm_sdata(IPCP): Sent code 1,4,22.
IPCP: sending Configure-Request, id 4
fsm_input(IPCP):2,4,22
fsm_rconfack(IPCP): Rcvd id 4 state=6
pppWrite[0]: len=18
np_up: 0 proto=21
ipcp: up
connected
adr our: 172.24.167.88 ip: 192.168.100.101 mask: 255.255.255.0
free heap: 1416
pppStopCB: unit 0
link_down: 0
ipcp: down
np_down: 0 proto=21
error: -6
pppWrite[0]: len=29
free heap: 1416
link_terminated: 0
error: -5
connecting…
ppp starting 4 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 19C8B4A3
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc[0]: got 60 bytes
pppWrite[0]: len=16
pppInProc: pbuf alloc 00207f08 <= here is the leak!!!
disconnecting by signal…
pppMainWakeup: unit 0 sig_hup -> pppHupCB
pppHupCB: unit 0
LCP: lowerdown state 6 -> 1
link_terminated: 0
error: -8
free heap: 1444
free heap: 1444
connecting…
ppp starting 5 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 917D3A37
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc[0]: got 9 bytes
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppHupCB: unit 0
link_terminated: 0
error: -8
free heap: 1444
free heap: 1444
connecting…
ppp starting 6 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 11DF1176
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=47
pppInProc: pbuf alloc 002084f4
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6D371B) PCOMPRESSION
pppWrite: pbuf alloc 00208ae0
pppWrite[0]: len=52
nPut: pbuf free 00208ae0
pppInput: pbuf free 002084f4
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=47
pppInProc[0]: got 32 bytes
pppInProc[0]: Dropping bad fcs 0x6414 proto=0xC021
pppDrop: pbuf len=24
pppDrop: pbuf free 002084f4 & 002084f4
pppInProc[0]: got 67 bytes
lcp_acki: Ack
link_established: 0
upap_lowerup: 0 s=0
pppWrite[0]: len=22
pap_sauth: Sent id 5
pppInProc: pbuf alloc 002084f4 <= possible leak!!!
link_down: 0
IPCP: loupap_timeout: 0 timeout 6 expired s=4
pppWrite: pbuf alloc 002084f4 <= I can’t understand that
pppWrite[0]: len=30
fsm_sdata(IPCP): Sent code 1,5,22.
IPCP: sending Configure-Request, id 5
fsm_input(IPCP):3,5,22
fsm_rconfnakrej(IPCP): Rcvd id 5 state=6
local IP address 172.19.60.85
pppWrite[0]: len=29
fsm_sdata(IPCP): Sent code 1,6,22.
IPCP: sending Configure-Request, id 6
fsm_input(IPCP):2,6,22
fsm_rconfack(IPCP): Rcvd id 6 state=6
pppWrite[0]: len=18
np_up: 0 proto=21
ipcp: up
connected
adr our: 172.19.60.85 ip: 192.168.100.101 mask: 255.255.255.0
free heap: 1416
pppStopCB: unit 0
link_down: 0
ipcp: down
np_down: 0 proto=21
error: -6
pppWrite[0]: len=29
free heap: 1416
link_terminated: 0
error: -5
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
connecting…
ppp starting 7 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 78DE6B3A
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=45
pppHupCB: unit 0
link_terminated: 0
error: -8
free heap: 1444
free heap: 1444
connecting…
ppp starting 8 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 D2E3DFA2
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=45
pppWrite[0]: len=16
pppInProc: pbuf alloc 002084f4 <= here is the leak!!!
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=45
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=45
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=45
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=45
pppHupCB: unit 0
link_terminated: 0
error: -8
free heap: 1444
free heap: 1444
connecting…
ppp starting 9 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 F51160C1
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc: pbuf alloc 00208ae0
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6E13DB) PCOMPRESSION
pppWrite: pbuf alloc 00000000 <= the first effect / syndrom of leaks!!!
pppInput: pbuf free 00208ae0
pppInProc[0]: got 1 bytes
pppInProc[0]: Dropping bad fcs 0x90DB proto=0xC021
pppDrop: pbuf free 00208ae0 & 00208ae0
pppInProc[0]: got 51 bytes
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6E256F) PCOMPRESSION
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc[0]: got 39 bytes
pppInProc[0]: got 7 bytes
lcp_acki: Ack
link_established: 0
upap_lowerup: 0 s=0
pap_sauth: Sent id 7
pppInProc[0]: got 5 bytes
fsm_rconfreq(LCP): Rcvd id 3 state=9
link_down: 0
auth_reset: 0
lcp_addci: L opt=5 937D6BD7
lcp_addci: opt=7
lcp_addci: opt=8
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6E3703) PCOMPRESSION
pppInProc[0]: got 47 bytes
pppInProc[0]: got 3 bytes
fsm_input(LCP):1,4,24
fsm_rconfreq(LCP): Rcvd id 4 state=8
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6E4897) PCOMPRESSION
fsm_sdata(LCP): Sent code 2,4,24.
lcp_addci: opt=7
lcp_addci: opt=8
pppWrite[0]: len=46
pppInProc[0]: got 36 bytes
pppInProc[0]: got 10 bytes
lcp_acki: Ack
link_established: 0
upap_lowerup: 0 s=0
pap_sauth: Sent id 8
pppInProc[0]: got 6 bytes
fsm_input(LCP):1,5,24
fsm_rconfreq(LCP): Rcvd id 5 state=9
link_down: 0
auth_reset: 0
lcp_addci: L opt=5 22F90AF2
lcp_addci: opt=7
lcp_addci: opt=8
fsm_sdata(LCP): Sent code 1,3,20.
LCP: sending Configure-Request, id 3
lcp_reqci: rcvd ASYNCMAP=0 PAP (C023) MAGICNUMBER (6E5A2B) PCOMPRESSION
fsm_sdata(LCP): Sent code 2,5,24.
pppInProc[0]: got 4 bytes
fsm_input(LCP):5,6,14
fsm_rtermreq(LCP): Rcvd id 6 state=8
fsm_sdata(LCP): Sent code 6,6,4.
pppInProc[0]: got 14 bytes
lcp_addci: opt=7
lcp_addci: opt=8
lcp_addci: opt=7
lcp_addci: opt=8
lcp_addci: opt=7
lcp_addci: opt=8
pppHupCB: unit 0
link_terminated: 0
error: -8
free heap: 1444
free heap: 1444
connecting…
connecting…
ppp starting 10 time
top stack2: 2110531
top stack3: 2110531
ppp started
pppStartCB: unit 0
auth_reset: 0
lcp_addci: L opt=5 B968D522
lcp_addci: opt=7
lcp_addci: opt=8
pppInProc[0]: got 63 bytes
pppInProc: pbuf alloc 00000000
pppInProc[0]: NO FREE MBUFS!
pppInProc[0]: Dropping bad fcs 0x5DD3 proto=0x202A
a lot of protocols of the PPP do not free pbuf from pppInProc!!! Ib pppInput functions ip_input and pppDrop are doing that.
It looks ok:
default:
int i;
goto out;
break;
drop:
#if LINK_STATS
out:
pbuf_free(nb);
return;
so I haven’t idea again where is the bug
Janusz
interesting things:
http://www.mail-archive.com/lwip-users@nongnu.org/msg00177.html
http://www.archivum.info/lwip-users@nongnu.org/2004-10/msg00001.html
I think I have found bug in the ppp.c. pppInProc allocates memory but after finish pppMain the memory is still allocated and wasted! Solution is pppDrop(pc) - I will try to do it and tell you about results.
best regards
Janusz
This is solution (pppDrop is necessary, I placed it at the finish for to be sure):
err_t err;
int pd = (int)arg;
struct pbuf *p;
PPPControl* pc;
if(!p) {
goto out;
pc->kill_link = 0;
pc->sig_hup = 0;
} else {
if(c > 0) {
} else {
pppDrop(pc); // or in line after PPPDEBUG((LOG_DEBUG, “pppMainWakeup: unit %d sio_read len=%d returned %d\n”, pd, p->len, c));
pbuf_free(p);
out:
pc->openFlag = 0;
kind regards
Janusz Uzycki
I have noticed the bug #17726 at http://savannah.nongnu.org/bugs/index.php
Janusz
