FreeRTOS + LwIP ATSAME70 Lock up
Hi all,
I’m using FreeRTOS + LwIP on a Microchip ATSAME70 MCU, and I’m facing a long-standing issue where the system eventually locks up, but only after using TCP sockets.
Here’s what I’ve tried and observed:
If I keep a TCP socket open continuously, the system locks up faster — sometimes within minutes or hours.
To work around this, I changed the design to only open a TCP socket briefly when I need to send data, and then immediately close and delete it (connect → send → close).
This extends the time before the lockup occurs, but it still eventually happens after enough TCP activity over time.
I’m seeing errors like:
memp_malloc: out of memory in pool TCP_PCB
memp_malloc: out of memory in pool NETCONN
I increased MEMP_NUM_TCP_PCB and MEMP_NUM_NETCONN which cleared the errors but my system is still locking up after a certain amount of time.
My TCP THREAD is:
/********************* TCP Thread Function *********************/
S8 res;
void TCP_THREAD(struct _tcp_descriptor* TCP)
	portTASK_USES_FLOATING_POINT();
	//Set handle for thread
	TCP->handle = xTaskGetCurrentTaskHandle();
	//Force close on start
	TCP->sockFlags |= TCP_FORCE_CLOSE_FLAG;
	TCP->txBuf.flags = 0;
	//Wait until low level is ready for a connection
	TCP_PHY_WAIT(TCP);
	//Enter TCP state machine
	while (1)
		//wait until woken, or timeout
		TCP->state = TCP_STATE_WAIT;
		ulTaskNotifyTake(pdTRUE, 10);
		//vTaskDelay(10);
		//Monitor PHY and NETIF status
		if (*(TCP->netifStatus) == false || *(TCP->phyStatus) == false){
			TCP_PHY_WAIT(TCP);
		//If not connected, attempt to connect
		if (TCP->linkStatus == false){
			TCP->linkStatus = TCP_CONNECT(TCP);
			TCP->tcpLastRx = sysGetMs() + 5000;
		}else if (TCP->sockFlags & TCP_FORCE_CLOSE_FLAG){
				TCP_CLOSE_SOCK(TCP);
				xSemaphoreGive(*(TCP->lwipMtx));
				TCP_PHY_WAIT(TCP);
		}else{
			//receive data if mailbox is not empty
			res = TCP_READ(TCP);
			//Add downtime between io events
			vTaskDelay(10);
			//Forward data if we have any
			if(!(TCP->txBuf.flags & TCP_BUF_DONE)){
				res = TCP_WRITE_FROM_BUF(TCP);
		if ((sysGetMs() > socketTimer + 180000) && TCP->linkStatus == true ) { // close socket every ...
           printf("Idle timeout, Closing socket... \n");
           TCP_FORCE_CLOSE_SOCK(TCP);
		   socketTimer = sysGetMs();
		//get high water mark
		RTOS.TCP.hwMark = uxTaskGetStackHighWaterMark( NULL );
I am fairly new at this so my understanding of the issue might be completely off.
Has anyone else run into a similar issue? Or any insight on how to deal with it would be greatly appreciated.
Thanks in advance.
For LWIP related support, I would suggest reaching out to the LWIP forum/mailing list.
Here are a couple of things I noted while taking a quick look:
  • The return value of ulTaskNotifyTake not checked here: Refer to these docs to see how task notifications can be used correctly: RTOS task notifications - FreeRTOS™
  • The fields in the struct _tcp_descriptor pointer (TCB) seems to be updated from a different thread/callback/ISR. If thats the case those fields are accessed concurrently from TCP_THREAD thread, you need mutexes to protect them from race conditions.
  • Verify the implementation of printf for your platform is thread safe.
Hi Tony,
thank you so much for your response. I have made some changes to my code based on your notes. So far it seems to be working fine but then it could take longer before it locks up. I will keep monitoring it and if it fails again I will try my luck on the LWIP forum as you suggested.
