I´m trying to use floating point on FreeRtos / LPC2368 / newlib environment !
Yes I know, float and small uC w/o hw-math is not the best, but is good enough to quickly start some tests.
I’m able to run math functions like sin, cos, …, but the system fails on sprintf( " … %f ").
I dig the network and I get confused about newlib and reentrancy!
At this time I don’t need functions like write_r …, to interface printf to UART, I’d like to get a formatted string.
Is anyone using sprintf with float data?
my gcc env:
gcc 4.2.1
newlib 1.15.0
FreeRtos 5.0.2
Not sure if it’s the same as on other micros but you may need to pass the following options to the linker to include the floating point version of vfprintf (called by printf)
I’m using newlib-1.15 w/o syscall.x for LPC2368: freeRTOS demo is working fine (HTTPserver task is using sprintf).
I add a new task to handle the UART, then I use sprintf to format a string before ask uart to send it: the system start to fail after a while, so I have reentrancy problems.
I stop the HTTPserver task and the system is fine until I add a %f on sprintf: if floatval is 0.0 all is fine, otherwise it crash.
I rebuilt the newlib using "–enable-newlib-multithread=yes" (configure phase). Nothing is changed. Compilation and link are fine: no missed references (I was waiting for at least one …_r function missing)
I’m lost!
Now
- looking the configure shell it seems that --enable-newlib-multithread=yes is already a default value and newlib package provide a dummy stubs for all syscall needed. Is it true?
- newlib heap: which one? The one provided by C (I have to set someting in boot.s?) or provide a wrap to freeRtos heap?
- _r functions: which are mandatory ?
- In which way I have to force the activation of the reentrancy?
Some of the FreeRTOS.org demos reduce the code size by including a file called printf-stdarg.c in the project to provide the sprintf functionality. This is a very cut down version and does not include floating point formatting. Does your project include this file? If it does, try removing it.
It’s simple, the support for float HAVE NOT BEEN included on the Newlib printf and all the family (sprint, vsprintf…)
(at least with the yagarto precompiled)…
You will have to recompile a new lib (good luck)…
Best way: Multiply your float by 1 000 or 1 000 000 (according to your application and the acceptable error) and use an integer to store your float, will be better for calcul letter.
