Greetings ,
I have implemented an application with freertos (nordic sdk 15.3 - freertos 10.0.0 )
which goes into low power and wakes up on two irqs (rtc and button).
When the button irq arrive turns on the system, performs operations
and then return to a low power state.
When entering low power the task are suspended , restored
on wake up.
The anomaly occurs when the system remains in the low
power state , when I wake up i find that the task
remains frozen / paused (in vTaskDelay / xEventGroupWaitBits ) for a time
proportional to the time it remained in low consumption .
I have found that if i set a define to 1 ( configUSE_DISABLE_TICK_AUTO_CORRECTION_DEBUG 1 )
the problem does not arise .
Anyone have any ideas on what to investigate (or a hint) to solve the problem ?
Thanks in advance for your kind collaboration
Best regards
Andy
