FreeRTOS ISR routine Handling , Callback Function
Missed the last point. I think the reference to clearing the interrupt is within the entry point for the IRQ, before the individual handler is called, and is relevant if you want to use nested interrupts - that is - allow other interrupts to be accepted while you are still processing an pre-existing interrupt.
