We have been using FreeRTOS with lwIP stack.
We would like to consider the possibility of using instead the IP stack supplied with FreeRTOS.
We are using an ATMEL ATSAME70Q21 on our embedded system.
The MAC driver for the lwIP stack is provided already with ATMEL ASF.
I would like to know if the ATMEL ATSAME70Q21 MAC is already supported by the FreeRTOS IP stack.
Do I need to develop a driver?
Can I use the driver supplied by ATMEL ASF?
Is there any working example that is supplied in the FreeRTOS package that can run on a demo board? We have an ATMEL SAM V71 Xplained Ultra.
thanks for the answer and link.
I’m trying to bring the project to Eclipse (since I don’t have Atmel Studio, nor Keil, nor IAR) and I’m encountering some compilation problems most likely related with ARM architecture:
instruction not allowed in IT block – msr psp,r0' FreeRTOS_IP line 690, external location: /tmp/ccjYz9a1.s C/C++ Problem instruction not allowed in IT block -- stmdb r0!,{r4-r11,r14}’ FreeRTOS_IP line 666, external location: /tmp/ccjYz9a1.s C/C++ Problem
make: *** [src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.o] Error 1 FreeRTOS_IP C/C++ Problem
recipe for target ‘src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.o’ failed subdir.mk /FreeRTOS_IP/Debug/src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7 line 18 C/C++ Problem
selected processor does not support vldmiaeq r0!,{s16-s31}' in Thumb mode FreeRTOS_IP line 688, external location: /tmp/ccjYz9a1.s C/C++ Problem selected processor does not support vstmdbeq r0!,{s16-s31}’ in Thumb mode FreeRTOS_IP line 664, external location: /tmp/ccjYz9a1.s C/C++ Problem
It seems that the compiler is generating code that is not supported by the Thumb instruction set…
I’m using an ATMEL SAME70, so I have set the project properties to
cortex-m7
architecture toolchain default
instruction Thumb
In the meantime I found that these errors como from the port.c file.
The file in use is from GCC/ARM_CM7, so since I use the ATSAM70E it should be the right file.
I believe that is the project configuration in Eclipse that is set with the wrong ARM processor.
In the meantime I found that these errors com from the port.c file.
make all
Building file: …/src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.c
Invoking: GNU ARM Cross C Compiler
arm-none-eabi-gcc -mcpu=cortex-m7 -mthumb -mthumb-interwork -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -g3 -I"/home/user/svn/FreeRTOS_IP/src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/include" -I"/home/user/svn/FreeRTOS_IP/src/Config" -I"/home/user/svn/FreeRTOS_IP/src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7" -std=gnu11 -MMD -MP -MF"src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.d" -MT"src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.o" -c -o “src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.o” “…/src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.c”
/tmp/ccNEesp1.s: Assembler messages:
/tmp/ccNEesp1.s:664: Error: selected processor does not support vstmdbeq r0!,{s16-s31}' in Thumb mode /tmp/ccNEesp1.s:666: Error: instruction not allowed in IT block -- stmdb r0!,{r4-r11,r14}’
/tmp/ccNEesp1.s:688: Error: selected processor does not support vldmiaeq r0!,{s16-s31}' in Thumb mode /tmp/ccNEesp1.s:690: Error: instruction not allowed in IT block -- msr psp,r0’
src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/subdir.mk:18: recipe for target ‘src/thirdparty/RTOS/freertos/FreeRTOSV10.0.0/Source/portable/GCC/ARM_CM7/port.o’ failed
Not read the rest of this thread, but just looking at these errors it is
almost certain the compiler command line is not setting the target MCU
correctly. You have to tell it which MCU architecture you are building
for, and which floating point library to use (which might be software
emulation if there is no floating point unit, or the architecture of the
floating point unit if there is).
At the moment I have another problem. Some files seem to be missing…
Several files try to include sam.h (which is the file that includes several others in my case should be same70q21.h. None of these files are present…
I copied them from a complete FreeRTOS distribution.
Now I get another error (unrelated I think) on NetworkInterface.c regarding the declaration:
typedef struct gmac_device { Gmac *p_hw
declaration in:
I cannot find the file that defines Gmac!
