leokyohan wrote on Saturday, February 09, 2013:
Hi
I’m trying to port FreeRTOS in Freescale MPC8641D Board. I’m using codewarrior for compiling and debugging the project. I used the MPC860 example which was available in the FreeRTOS interactive forum as a reference. I know this issue is a bit port specific one. But any help in the FreeRTOS behaviour will be really useful.
As the first step in porting I was able to generate the hardware timer interrupt which is arriving at every 1ms and I called the function vTaskIncrementTick() in the handler.
Stack initialization functions are done according to the reference manual and the example provided. (I dont know whether any problems in that, but everything look fine).
Then I created 2 tasks of same priority both running in an infinite loop.
I have the following observations/issue in my port.
1. My first task is running properly. But context switch is not happening even though I have given vTaskDelay in the first task. When I give higher prority to the second task, that task is getting executed continuously and it is not context switching to the first task. Please note that #define configUSE_PREEMPTION is set as 1 for me and I’m using the interrupt vector table auto-genrated by codewarrior.
2. Inside the vTaskIncrementTick() function, first time it is going to the ++xTickCount; section and it is getting incremented, but from the next interrupt it is always going to the ++uxMissedTicks; section of the code.
( Here I’m getting a strange behaviour: If I’m putting a delay after the interrupt enable part of prvPortSetupInterrupts( void ) function, the control is going to the xTickCount section more than once according to the delay. When it is a big delay xTickCount is reaching more than 40000. But once the delay period is over it is going to the uxMissedTicks section even though the uxSchedulerSuspended value (which I can monitor in the codewarrior watch window) is zero. Then my first task is running in parallel to this I think.)
3. I double checked the timer interrupt and it is running continuously and generating an interrupt at every 1ms which is calling the vTaskIncrementTick.
4. When it is going to the missedTicks section in the readylist it is showing the number of tasks as 3 (I think they are my 2 tasks + the idletask)
5. I think sometimes it is hanging after the control going to the uxMissedTicks. (I’m not confident about this observation)
Below is the code I wrote for prvPortSetupInterrupts and vPortIntHandler.
static void prvPortSetupInterrupts( void )
register long aMSR;
IMMR_port->im_pic.tfrr = 0x000003E8;
IMMR_port->im_pic.gtdr0 = 0x00000001;
IMMR_port->im_pic.gtvpr0 |= 0x800F0040;
IMMR_port->im_pic.ctpr0 = 0x00000000;
//interrupt reset
while (IMMR_port->im_pic.gcr & MPC86xx_PICGCR_RST);
IMMR_port->im_pic.gcr = MPC86xx_PICGCR_MODE;
//timer setup
IMMR_port->im_pic.tcr = 0x00000000;
IMMR_port->im_pic.gtbcr0 = 0x0000A299;
IMMR_port->im_pic.gtvpr0 &= 0x7FFFFFFF;
//Enable Interrupt
asm
mfmsr aMSR
ori aMSR, aMSR, 0x8000
mtmsr aMSR
sync
//here I put a Delay for xtickcount to get incremented (dont know why this behaviour)
void vPortIntHandler( )
regist=IMMR_port->im_pic.iack0; //Interrupt Acknowledgement
vTaskIncrementTick();
#if ( configUSE_PREEMPTION == 1 )
vTaskSwitchContext();
IMMR_port->im_pic.eoi0=0; //end of interrupt
//reset timer
IMMR_port->im_pic.gtbcr0 |= 0x80000000;
IMMR_port->im_pic.gtbcr0 &= 0x7FFFFFFF;
As I don’t know what exactly the problem is, any inputs which point out what can cause this type of behaviour will be really useful.
Thanks & Regards
LEO
