FreeRTOS How to Use Secondary DNS?
I am working on a FreeRTOS project and the network that I am using has two separate DNS servers. This week the primary DNS server went down and my FreeRTOS devices no longer work. Is there a way that I can modify my devices to use the secondary DNS instead of the primary?
If I can find where this secondary DNS would be stored I should be able to solve this.
Thanks for anyone who decides to help!
Hello Drowsell - please share the version of FreeRTOS-Plus-TCP stack you are working on. Thanks.
FreeRTOS+TCP V2.4.0 is what I am using. Is this the information you were looking for?
Thank you.
Unfortunately V2.4.0 doesnt contain secondary DNS support. Refer to this open ticket → [Feature Request] Any plans to support a second DNS server? · Issue #564 · FreeRTOS/FreeRTOS-Plus-TCP · GitHub.
However, the good news is that we have addressed the feature request in our ongoing development branch here and will be part of our next release V4.0.0.
Look forward to seeing this in a future release.
As a temporary solution, you can change the DNS address as soon as you notify that all lookups fail.
The following function should set a new DNS address:
void vSetDNSAddress( uint32_t * ulDNSServerAddress )
    FreeRTOS_SetAddressConfiguration( NULL, /* pulIPAddress */
                                      NULL, /* pulNetMask */
                                      NULL, /* pulGatewayAddress */
                                      &ulDNSServerAddress );
And, if you like, look up the current DNS address:
uint32_t ulGetDNSAddress( void )
    uint32_t ulAddress;
    FreeRTOS_GetAddressConfiguration( NULL, /* pulIPAddress */
                                      &ulAddress );
    return ulAddress;
As Nikhil wrote, you can already find it in IPv6_integration.
It will most probably not be implemented in the current main branch.
