Recently I noticed FreeRTOS kernel added CMake support and I tried to add it as well in my project.
set(FREERTOS_PORT "GCC_ARM_CM3" CACHE STRING "" FORCE)
set( FREERTOS_HEAP "4" CACHE STRING "" FORCE)
FetchContent_Declare(freertos_kernel
GIT_REPOSITORY https://github.com/FreeRTOS/FreeRTOS-Kernel.git
GIT_TAG V10.6.1)
FetchContent_MakeAvailable(freertos_kernel)
target_link_libraries(freertos_kernel PUBLIC freertos_config)
But after compilation it gives me the following error:
projectdir/build/_deps/freertos_kernel-src/portable/MemMang/heap_4.c:432:24: error: cast increases required alignment of target type [-Werror=cast-align]
pxFirstFreeBlock = ( BlockLink_t * ) pucAlignedHeap;
I have -Wcast-align in compile option flags.
The error disappears if I remove the option flag.
Should I trust it and suppress the compile flag for the freertos target?
Compiler version
arm-none-eabi-gcc.exe (GNU Arm Embedded Toolchain 10.3-2021.10) 10.3.1 20210824 (release)
Target MCU: Cortex-M4
