FreeRTOS + GCC + CMake
I tried to add FreeRTOS on my CMake Project but in compile time I get some error like this:
[build] ../system/FreeRTOS/portable/GCC/ARM_CM3/portmacro.h:135:51: error: unknown type name 'inline'
[build] **attribute**( ( always_inline ) ) static inline uint8_t ucPortCountLeadingZeros( uint32_t ulBitmap )
I think this error happen because in the FreeRTOS, CMakelists.txt at line 296 say to compiler use C90 standard.
set_property(TARGET freertos_kernel PROPERTY C_STANDARD 90)
I tried with C99 and C11 unfortunately got error to ASM line’s like this:
[build] /usr/bin/arm-none-eabi-gcc -DprojCOVERAGE_TEST=0 -I../system/FreeRTOS/include -I../system/FreeRTOS/portable/GCC/ARM_CM3 -isystem ../system -g -fdiagnostics-color=always -Wall -Wextra -Wpedantic -Werror -std=c11 -MD -MT system/FreeRTOS/CMakeFiles/freertos_kernel.dir/portable/MemMang/heap_4.c.obj -MF system/FreeRTOS/CMakeFiles/freertos_kernel.dir/portable/MemMang/heap_4.c.obj.d -o system/FreeRTOS/CMakeFiles/freertos_kernel.dir/portable/MemMang/heap_4.c.obj -c ../system/FreeRTOS/portable/MemMang/heap_4.c
[build] /tmp/cc7OqtJX.s: Assembler messages:
[build] /tmp/cc7OqtJX.s:219: Error: selected processor does not support requested special purpose register -- `msr basepri,r3'
[build] /tmp/cc7OqtJX.s:220: Error: selected processor does not support `isb ' in ARM mode
[build] /tmp/cc7OqtJX.s:221: Error: selected processor does not support `dsb ' in ARM mode
but when I change this line to use GNU99 standard, error is gone!
Target
Development board: [STM32F103CBT6]
Instruction Set Architecture: [ARM Cortex-m3]
IDE and version: [vscode]
Toolchain and version: [GCC arm-none-eabi-8.3.1]
Host
Host OS: [Linux]
Version: [Debian 11.6]
when I add target_compile_options to freertos_config and add -mcpu=cortex-m3
-mthumb flag kernel compile with c99 without error but with c90 has error
    target_compile_options(freertos_config INTERFACE
    -mcpu=cortex-m3
    -mthumb
Does it compile with the -Wpedantic option removed?
[edit] I was able to try this myself and see that isn’t the cause, and concur setting the explicit C standard is. Either updating the cmake file or using __inline__ instead of inline within the port specific header could be options - I will discuss internally then update the github bug report accordingly.[/edit]
Thank you, I waiting for your feedback :smiley:
