FreeRTOS_FTP_server.c does not compile if ffconfigTIME_SUPPORT is 0
rasty1 wrote on Wednesday, August 03, 2016:
What do I miss?
Thanks
Rasty
./FreeRTOS-Plus-TCP/protocols/FTP/FreeRTOS_FTP_server.c: In function ‘prvSizeDateFile’:
…/FreeRTOS-Plus-TCP/protocols/FTP/FreeRTOS_FTP_server.c:2322:27: error: ‘FF_Stat_t’ has no member named ‘st_mtime’
time_t secs = xStatBuf.st_mtime;
In function prvSizeDateFile
if( xSendDate != pdFALSE )
FF_TimeStruct_t tmStruct;
time_t secs = xStatBuf.st_mtime; <<------ no st_mtime
heinbali01 wrote on Wednesday, August 03, 2016:
The “MDTM” command is quite essential to FTP. It needs support for time & date in +FAT.
So unless you have a good reason not to use it, I would enable it in your FreeRTOSFATConfig.h:
#define ffconfigTIME_SUPPORT      1
and also include the source file “ff_time.c”.
Regards
I have several reasons why I try to remove it
  1. I do not have RTC
  2. I was trying to optimize footprint
  3. I had the impresion that some “time” stuff drawn in from glibc. But I’m not sure.
heinbali01 wrote on Thursday, August 04, 2016:
I do not have RTC
But you dohave NTP :slight_smile:
What I often do is synchronise with NTP and use FreeRTOS to maintain the real time.
I’m not sure if it saves a lot of code. Have you calculated that?
I had the impression that some “time” stuff drawn in from glibc. But I’m not sure.
Not that I’m aware off. Several time-functions have been rewritten in order make it independent from the libraries provided by the compiler.
Now if you insist on not using time-support, I (or you) could make a change, remove the MDTM line from:
    static const char pcFeatAnswer[] =
        "211-Features:\x0a"
#if( ffconfigTIME_SUPPORT != 0 )
        "MDTM\x0a"
        " REST STREAM\x0a"
        " SIZE\x0d\x0a"
        "211 End\x0d\x0a";
and also:
	#if ffconfigTIME_SUPPORT == 0
		xLength = snprintf( pcCOMMAND_BUFFER,
			sizeof( pcCOMMAND_BUFFER ),
			"213 19700101000000\r\n");
	#else
		  // return the time
