sarayuks wrote on Thursday, August 27, 2015:
Hi ,
I was trying to port the FreeRTOS for my xilinx Microblaze VC709 board . I used the sample demo application you had provided in the site for the KC705.
I see that you have code which handles the timer interrupt and the Uart interrupt handler . I would like to know if i can configure the RTOS code to disable or not use the UART interrupt specifically ?
I am basically trying to reduce the size of my RTOS elf by reducing the functionalities to the basic minimum subset i would need . Are there any flags that i can use to disable certain particular functionalities like the above ?
Any lead in this would be of great help .
Thanks in advance.
Thanks and Regards
Sarayu
