Hi all,
I added a task through MPLAB Harmony V3 and suddenly the entire code stopped working and when debugging it seems stuck in the function below that seems to address the freeRTOS.
Attached is a picture of the call stack (cannot copy and paste the test).
Going back up the stack, it seems it might be originated by vTaskStartScheduler().
I have six tasks each allocated with 1024 bytes task stack buffer (I think that’s what it is called). But the micro has 512 KB of SRAM so it seems that’s not the case…
BUT how can I make sure that is definitely not the case?
No idea how to figure out what it is or how to fix it…
Help would be much appreciated…!
void vApplicationMallocFailedHook( void )
/* vApplicationMallocFailedHook() will only be called if
configUSE_MALLOC_FAILED_HOOK is set to 1 in FreeRTOSConfig.h. It is a hook
function that will get called if a call to pvPortMalloc() fails.
pvPortMalloc() is called internally by the kernel whenever a task, queue,
timer or semaphore is created. It is also called by various parts of the
demo application. If heap_1.c or heap_2.c are used, then the size of the
heap available to pvPortMalloc() is defined by configTOTAL_HEAP_SIZE in
FreeRTOSConfig.h, and the xPortGetFreeHeapSize() API function can be used
to query the size of free heap space that remains (although it does not
provide information on how the remaining heap might be fragmented). */
taskDISABLE_INTERRUPTS();
for( ;; );
This is going back up the call stack… It seems some task pointer NULL in task create??
#else /* portSTACK_GROWTH */
StackType_t *pxStack;
/* Allocate space for the stack used by the task being created. */
pxStack = pvPortMalloc( ( ( ( size_t ) usStackDepth ) * sizeof( StackType_t ) ) ); /*lint !e9079 All values returned by pvPortMalloc() have at least the alignment required by the MCU's stack and this allocation is the stack. */
if( pxStack != NULL )
/* Allocate space for the TCB. */
pxNewTCB = ( TCB_t * ) pvPortMalloc( sizeof( TCB_t ) ); /*lint !e9087 !e9079 All values returned by pvPortMalloc() have at least the alignment required by the MCU's stack, and the first member of TCB_t is always a pointer to the task's stack. */
if( pxNewTCB != NULL )
/* Store the stack location in the TCB. */
pxNewTCB->pxStack = pxStack;
/* The stack cannot be used as the TCB was not created. Free
it again. */
vPortFree( pxStack );
